Is this normal fuel consumption normal???
  • ZookFastback
28 Jun 2012 09:20 #43061 by ZookFastback
Replied by ZookFastback on topic Re: Is this normal fuel consumption normal???
I get 450k's plus per tank so I think you have a problem for sure. Mine warms up and temp hits normal after about 5 mins, nothing like your length of time. You do put the Jimny in 5th gear hey? ;)
  • Dan13l
02 Jul 2012 03:34 #43370 by Dan13l
Haha yea I do use 5th and the hubs are working fine.
Can anyone give me a bitta insight I've done a bit of testing with the water temp and engine temp and I believe it could be a faulty thermostat but if where I believe it is, it's going to be a pain in the backside to do :angry:
Is it located pretty much right behind and underneath the intake manifold? And if so how can I remove it with our having to pull apart the rest of the engine to get to it haha?
Cheers
02 Jul 2012 16:09 #43398 by mcjimny
All i can find about it say so, not sure if it differs between engines. Have you tried the test i posted before to diagnose the stat as being at fault?
  • Dan13l
03 Jul 2012 08:23 #43433 by Dan13l
Yea I did and its just stats cold for ages then slowly starts to get warm but never to the point of not being able to touch it so I presume and hope that is the problem, but there is only one way to find out... Time to pull off the intake manifold :unsure:
  • ne-crock
06 Jul 2012 16:28 #43603 by ne-crock
Replied by ne-crock on topic Re: Is this normal fuel consumption normal???
hey, just been reading through this and i'm getting about 15 mpg from my car and its standard bar 205/70/15 m/t's
did you have any luck sorting it out, because i think there must be a problem with mine also?
  • mark1971
06 Jul 2012 16:35 #43605 by mark1971
Replied by mark1971 on topic Re: Is this normal fuel consumption normal???
15 MPG???? my mates 3.9l V8 Disco does more than that...... :ohmy:
Time to create page: 2.277 seconds
