Brake hoses
  • Dave c
14 Jun 2012 21:37 #42384 by Dave c
Brake hoses was created by Dave c
Getting close to needing to get axles piped with hoses breathers air etc plan to use Goodridge or Aeroquip bit confused over there sizing Goodridge call brake size fittings 600 series and Aeroquip -3 anyone know if its interchangable ??? and does it use the same hose ??? and the best place to buy it dont want stainless just good old plated will do fine checked out Demon theives damn them boys can charge
15 Jun 2012 16:24 #42417 by kirkynut
Replied by kirkynut on topic Re: Brake hoses
Are you talking about flexi's or rigid brake pipes?
If you are talkinga bout flexi's, the Bigjimny shop is where to get them from!!!
15 Jun 2012 16:47 #42418 by mlines
Replied by mlines on topic Re: Brake hoses
Standard fitments are here - www.bigjimny.com/store/index.php/off-roa...hose-sets/p_122.html - suitable for up to a 5" lift
The standard set of three is £66. Custom ones are available to order in any length/style you require. Cost is mainly dependent on the fittings required at each end rather than the length. So banjos etc. for calipers will change the price but not by much.
  • zuki andy
15 Jun 2012 17:30 #42420 by zuki andy
Replied by zuki andy on topic Re: Brake hoses
try a local hydraulics hose firm, most of them stock the goodridge type hose, and will make them up to your requiements.
  • Dave c
16 Jun 2012 10:02 #42455 by Dave c
Replied by Dave c on topic Re: Brake hoses
Thanks guys thinking maybe then if suitable for a 5 inch lift the Jimny store ones could do me fine does anyone know the actual length of the pipes so i can have a measure up ? just need to be sure as my axles are a bit wider and front calipers are mounted at 9 O clock rather than 12 O clock as on a jimny axle
Time to create page: 0.197 seconds
