manual locking hubs .
- Thank you received: 77
10 Jun 2012 06:43 #42108
by robs5230
standard jimny - for now
manual locking hubs . was created by robs5230
i was going to permanently lock my auto hubs ( removing vac pipes and manually locking the collars ) but i have managed to source a pair of aisin manual hubs complete with the bolts and cone washers
does anyone have any suggestions about stripping , cleaning , regreasing etc before i fit ??
i will be ordering the adapter plates shortly from martin.
also when fitting the hubs should the jim be in 2wd , 4wd and should the hubs be locked or unlocked ??
cheers rob
cheers rob
10 Jun 2012 07:14 #42109
by facade
Replied by facade on topic Re: manual locking hubs .
Clean & lubricate.
There is a youtube video, but here is a web page
forum.ih8mud.com/79-95-toyota-truck-tech...ing-hub-rebuild.html
You fit the outside part then the centre has to be fitted correctly: some of the lugs are larger than the others.
Best done in 4wd, then you can jack up a front wheel and see if they locked.
10 Jun 2012 07:31 #42110
by robs5230
Replied by robs5230 on topic Re: manual locking hubs .
cheers. found the youtube vid and it looks easier to follow.
rob
rob
