Engine Light Coming On?
  • Pete E
09 Jun 2012 22:15 #42095 by Pete E
Engine Light Coming On? was created by Pete E
I have a strange issue that the engine light comes on if i reverse any distance..It then stays on for a day or two, and then goes out..
Oil and other fluid levels are ok and there isn't anything obviously wrong with the engine when its running ie temp is normal and performance same as usual.
Any ideas what the "problem" is and whether it is something to be worried about?
Thanks in advance..
Peter
  • 247sniper
09 Jun 2012 22:29 #42097 by 247sniper
Replied by 247sniper on topic Re: Engine Light Coming On?
whats your speedo cable like? Does the needle move quite a lot?
Steve.
  • Pete E
09 Jun 2012 22:44 #42099 by Pete E
Replied by Pete E on topic Re: Engine Light Coming On?
Nope, needle behaves normally..in fact considering that it has just over 100K on the clock (54 plate) she still drives very well..
  • 247sniper
09 Jun 2012 23:03 #42101 by 247sniper
How far do you have to reverse before the MIL light comes on?
Steve. :)
  • Pete E
09 Jun 2012 23:12 #42102 by Pete E
Seems to be about 10 -20 yards or so..def a bit further than just reversing off the drive, but at the same time, its not like reversing 1/2 a mile back up a green lane either..
If I disconnect/reconnect the battery, the light goes out and stays out (until next time) or it will go out on its own after a days or so..
10 Jun 2012 03:12 #42106 by kirkynut
Sounds peculiar!
Ideally you need to leave the light on and get a diagnostic code reader on it to see what it says to give you half a clue!
Time to create page: 0.162 seconds
