2005 Jimny Transponder key coding
- electricblue
07 Jun 2012 04:13 #41885
by electricblue
Replied by electricblue on topic Re: 2005 Jimny Transponder key coding
Thanks for the information guys.
- electricblue
07 Jun 2012 04:28 #41886
by electricblue
I'm not sure that you would need a new immobiliser or ecu, as suzuki can completely programme new keys to the immobliser and there is a procedure to code the immobiliser to the ecu in the manual.
I spoke to a guy at the suzuki dealership here and he gave me the part numer I needed for the correct remote & transponder key for my car: 37145-55JV1.
He said if I can get a second hand key with that part number and get a new blade cut to suit my car they can programme it to the car.
I also found a manual online for the suzuki key programmer which has manual procedures in it for programming just the remote central locking part of the key. However the jimny wasn't included. Although I am wondering of one of the other procedures will work.
I have attached the manual to this post.
- electricblue
07 Jun 2012 04:33 #41887
by electricblue
I have also been thinking that you could buy 4D65 transponder chips online quit inexpensively from ebay. It would be possible to ket just a plan key cut and get the transponder programmed to the Imobbiliser Unit at suzuki.
Or buy a key programmer, a cheap one would set you back $200-300 that can susposedly program the jimny ICU.
Ebay also sell transponder key blanks for the jimny without central locking for around $30AUD.
One probelm though is that I needed to provide my vin to suzuki to get the correct part number, as suzuki change transponder chips and remotes alot across models.
So there is no gaurantee that if I bought an aftermarket it would be corret as the imformation out there seems to be vague at best.
07 Jun 2012 07:55 #41894
by facade
My bad. I meant that you go to a scrapyard and get immobiliser, engine ecu, keys (and lock barrels) and change everything as a set.
Unless you get "mates rates" at Suzuki getting them to supply and code a key to the car is a more expensive option. (At least it is over here)
Replied by facade on topic Re: 2005 Jimny Transponder key coding
electricblue wrote: I'm not sure that you would need a new immobiliser or ecu, as suzuki can completely programme new keys to the immobliser and there is a procedure to code the immobiliser to the ecu in the manual.
- electricblue
14 Jul 2012 12:02 #44145
by electricblue
I have made some progress with programming a key to my Jimny.
The transponder for the jimny turns out to be texas crypto 4d65. I purchased a chip from ebay(AUS$15) along with a chinese silca key progamming machine (AUS$170), which can read and programm the immobilizer in the jimny. So using this machine I was able to successfully progam a transponder key to my car and clear the old key.
I have also been able to find out that the programming procedure for the remote is actually a manual procedure as I have found it in my workshop manual.
However i have tried programming two TS002 remotes I have with no success.
I am hoping that some nice chap that has a jimny around the 2005 mark that has keyless entry would be willing to open the key up and tell me the part number on the remote unit inside the key?
I am aware that different countires might use different remotes but it's worth a shot.
I have seen keys on ebay that are either TS002 remotes or omron kl3. I just wanted to check before I buy one just to try.
- electricblue
15 Jul 2012 09:23 - 15 Jul 2012 09:27 #44175
by electricblue
Ok I have made some more progress and I thought I would post it as the information may be useful to someone.
I don't know why I didn't do this to start with, but I went and looked at the keyless entry receiver unit in the car and found the make and model number which is ALPS Electric model number 37190A7.
I had rembered seeing this number in the owners manual listed in the section that tells you how to change the battery in the remote key. There was a little blurb saying receiver model number 37190A7 and transmitter model number 37182-A7 conform to standard blah blah blah.
So googling this model number revelled transmitter keys with the correct remote for my jimny. I found old listings on ebay but none currently for sale.
So in summing up the transponder chip ID is texas crypto 4d65 which can be purchased and programmed into the immobliser, and in fact some lock smiths have a machine that can plug into your carvia the can-obd II port to programm the transponder. No need to go to Suzuki.
Once you know the correct model number for your remote then extra remotes can be purchased and programmed manually using the following attached procedure.
Last edit: 15 Jul 2012 09:27 by electricblue. Reason: forgot attachement
Time to create page: 0.115 seconds
