Steering wobble
  • JimBru
11 Oct 2010 17:02 #5078 by JimBru
Replied by JimBru on topic Re:Steering wobble
Adamski wrote:
JimBru wrote: mine was cured by getting the disks machined and a wheel balenced :)
What does getting the discs machined involve? Did your wheels only wobble when applying the brakes?
it seemed to make the wobble a lost worse when braking, I had the front stripped down any way so thought it would be rude not to do it.
I basically gave them to the bloke at work who works in the machine shop, he stuck them on the lathe and straightened up all the faces (not sure waht the technical term is :unsure: ), he did say one was quite warped think he took about 1mm off??
Was worth a try for free :)
  • ooky_123
12 Oct 2010 06:11 #5082 by ooky_123
Replied by ooky_123 on topic Re:Steering wobble
Technical Term here .... you had the discs skimmed :)
I replaced my discs and pads. it improved things a lot, but I think I need to get the wheels balanced too
12 Oct 2010 10:01 #5087 by kirkynut
Replied by kirkynut on topic Re:Steering wobble
This goes back to getting the wheels balanced on the car. You just have to mark the wheel and a stud to make sure you put it back on in the same place. If you can find somewhere to do it now.
  • JimBru
12 Oct 2010 12:07 #5092 by JimBru
ooky_123 wrote: Technical Term here .... you had the discs skimmed :)
thats the phrase, i had brain freeze lol
Time to create page: 0.103 seconds
