Steering wobble
  • colin_y
30 Jul 2010 08:45 #3995 by colin_y
Steering wobble was created by colin_y
I would like to pass on a wee bit of info to you all.
I was having difficulty with a steering wobble @ 50mph and went down the usual route of wheel balance ,kingpins etc.
I found the issue was a build of of aluminium oxide on the face of the wheel as it fits to the hub. the problem was gone until I changed the pads and refitted the wheels. I did not mark them before removal (who does) and only when i removed them again was the problem apparent.
quick going over with 80 grit and some copper slip to minimise a repeat and bingo!
worth checking when alloy wheels are off.
colin
  • andyw
16 Aug 2010 13:22 #4251 by andyw
Replied by andyw on topic Re:Steering wobble
:woohoo: :woohoo: :woohoo: Glad I read this last week!!!!!!!!!!!
I've had the Death Wobble for a long time like you do, I bought the Shims to try off Martin, but there still here, not got around to it. :huh:
Done what you suggested with the wheels and took it for a drive and the DW did'nt come, thought any minute now but it did'nt come at all.
So try cleaning the mating faces up, also I blew all my tyres up to 25lbs just to try, so no DW , yes pleased so far.
Thanks for posting, I would'nt of thought of it B) :)
Andy
  • colin_y
16 Aug 2010 13:45 #4252 by colin_y
Replied by colin_y on topic Re:Steering wobble
Glad to be of assistance.
Alloy wheels and steel surfaces do not like each other. Since this I have changed the disks and pads on my shogun and done the same with all front alloy wheel surfaces and it drives better now as well.
ATB
Colin
  • Adamski
10 Oct 2010 19:07 - 10 Oct 2010 19:10 #5064 by Adamski
Replied by Adamski on topic Re:Steering wobble
I'm going to give this a try as since fitting my wider offset wheels my steering wobble is really bad between 30mph - 40mph :( . Failing that, have many people successfully cured their wheel wobble by replacing the wheel & kingpin bearings?
Last edit: 10 Oct 2010 19:10 by Adamski.
  • JimBru
11 Oct 2010 12:58 #5073 by JimBru
Replied by JimBru on topic Re:Steering wobble
mine was cured by getting the disks machined and a wheel balenced :)
  • Adamski
11 Oct 2010 13:49 #5074 by Adamski
JimBru wrote: mine was cured by getting the disks machined and a wheel balenced :)
What does getting the discs machined involve? Did your wheels only wobble when applying the brakes?
Time to create page: 0.103 seconds
