front caliper stripdown
- Thank you received: 77
10 May 2012 20:10 #39890
by robs5230
standard jimny - for now
front caliper stripdown was created by robs5230
got a sticky front caliper. just changed the pads and one pad on the drivers side worn to the metal nearly .
what sort of job is it to strip , clean re seal and re build ??
are the bits available ?
cheers
cheers
- supergaz
10 May 2012 20:19 #39895
by supergaz
Replied by supergaz on topic Re: front caliper stripdown
Just come inside from doing mine, its a fiddly job to do but much cheaper than new calipers.
The parts are available from Jimnybits or Biggred.co.uk
www.bigjimny.com/index.php/bigjimny-blog...42-drivechain-v15-42
10 May 2012 20:34 #39900
by robs5230
Replied by robs5230 on topic Re: front caliper stripdown
cheers gaz how long did it take ?
- supergaz
10 May 2012 20:41 #39902
by supergaz
Cleaning and re-fitting just 1 caliper was about an hour. Then waited for my assistant to come home to do the honours of jumping on the brake pedal.
I'm a commercial brake tester engineer for a leading garage equipment company and super fussy when it comes to brakes! But have never stripped a caliper until now.
10 May 2012 20:53 #39907
by robs5230
many thanks , another job to do
spring spacer first, gotta look right eh ?
- 247sniper
10 May 2012 22:16 #39918
by 247sniper
Replied by 247sniper on topic Re: front caliper stripdown
What sort of prices are the kits guys.
Or did I miss it on the link page :laugh:
Steve.
Steve.
