front caliper stripdown
  • Mumbo Jimbo
  • Visitor
  • Visitor
12 May 2012 07:27 #40036 by Mumbo Jimbo
Replied by Mumbo Jimbo on topic Re: front caliper stripdown
Great video - he makes putting the piston seal on look really easy. Took me quite a few goes.
  • 247sniper
  • Visitor
  • Visitor
12 May 2012 08:47 #40039 by 247sniper
Replied by 247sniper on topic Re: front caliper stripdown
They look like brand new calipars ! :laugh:
12 May 2012 12:28 #40047 by kirkynut
Johnniehec wrote: Kirkynut, did you do the same as me? Stupidly I squirted everything with lubricating oil, well actually it was Tesco's cheapo version which is probably 99% thinners! just had to touch the rubber slider boots and they fell apart, then I had to order the kit to get replacements. Don't put Spray Lube anywhere near the Rubber components!!!
John.
I had used WD40 on the sliders as they were seized as a seized thing! I didn't notice them swell though but they were already tired and perishing and thus in need of replacement!
I had also been using waterproof bearing grease made by Lucas Oils and had not noticed any swelling in the rubbers - however, owing to them being knackered they were not keeping any water out, hence they had seized and kept seizing.
Just in case though, I now have a very large tub of red rubber grease made by Millers I think that came via eBay and will be using that.
The video is very good but how he got the second rubber boot to stay located when he pushed it through so easily I'll never know - mine were a git and I think martin found the same as he mentions it in his guide. Mind you, I didn't take my calipers off the car and did it without disturbing the hydraulics as the calipers themselves are fine and do not need reconditioning yet.
In the summer months I'll re-build the spare set I have unless I can get hold of some of those Lucas ones in the video as their sliders are the bolt that holds the caliper assembly to the caliper bracket and therefore doesn't seize like these Aisin ones.
15 May 2012 11:56 #40331 by robs5230
ok seals delivered today . any tips for cleaning the body of the caliper before i rebuild them ?
cheers
standard jimny - for now
  • supergaz
  • Visitor
  • Visitor
15 May 2012 16:30 #40351 by supergaz
Replied by supergaz on topic Re: front caliper stripdown
Brake cleaner fluid, parafin or Diesel.
15 May 2012 20:19 #40369 by robs5230
one caliper resealed and back on. what a nasty job. the sliders were about shot , had to get medieval on them to get them somewhere near smooth, particularly the leading one. real tricky job cleaning all the grooves out. passenger side to do then bleeding. the article from martin and the video found on here really helped. good news is that the drivers side wheel spins freely now :)
Time to create page: 0.247 seconds
