Well its Clutch time !
- Fearghal Murphy
30 Apr 2012 17:02 #39014
by Fearghal Murphy
Well its Clutch time ! was created by Fearghal Murphy
My Jimny, is just about to pass the 70k mile horizon, it is still on its first clutch, and was never off roaded until i bought it at 60k miles !
Have a clutch kit on order, and the tools at the ready. Downloaded the guide from here and have experience doing heavy jobs like this. However does anyone here know of significant or crucial areas to watch out for regarding a Jimny Clutch fit ?
Many thanks, all you guys help is always appreciated ! Charity OFFROAD challenge in October so looking forward to a well prepped Jimny for that !
30 Apr 2012 20:04 #39028
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Re: Well its Clutch time !
My two pence.
After you slide the gearbox back and remove the old clutch don't waste time trying to swap the release bearing in situ. Remove the whole plate and bearing together. Swap it where you can see and then offer it back up (the old bearing should just slide off and the new one slides on. A little hooked screw driver or pick is good for hooking the spring back on to hold the plate back on to the gearbox.
Hope that helps.
Hope that helps.
Grey pick up Jimny
- wanderinstar
30 Apr 2012 20:25 #39034
by wanderinstar
Replied by wanderinstar on topic Re: Well its Clutch time !
While you have the clutch out I would fit a breather kit to the gearbox, as it is extremely difficult to fit in situ.
- adamjimny
30 Apr 2012 23:34 #39046
by adamjimny
Replied by adamjimny on topic Re: Well its Clutch time !
Yeah follow j999pre advice as he gave me as i was stuck but then it made it a breeze. Takes about 4 hours first time just either buy an alignment tool or make on other wise its nye on impossible
sent from my Samsung Galaxy S2 using Tapatalk
- goatboy
01 May 2012 07:46 #39055
by goatboy
Replied by goatboy on topic Re: Well its Clutch time !
Is your clutch slipping? From your orginal post it kinda implies you are changing it just because of the mileage?
If it ain't broke why fix it?
- Fearghal Murphy
02 May 2012 20:55 #39192
by Fearghal Murphy
Replied by Fearghal Murphy on topic Re: Well its Clutch time !
Thanks for all the feedback gang , tis much appreciated and sounds like real eh sound advice , top stuff !
Goatboy, yep she is slipping, not too badly at present but the other day driving to work was brutal, not bad today but still not great !
Thanks again folks, i shall keep ya updated, also i have a breather kit here ready to go !
Cheers !
Cheers !
Time to create page: 0.296 seconds
