Fitting Pro Comp Dampers HELP!
  • Beano
24 Apr 2012 19:11 #38518 by Beano
Fitting Pro Comp Dampers HELP! was created by Beano
Folks,
Just purchased a rear pair of Pro Comp dampers (ES1000) and they wont fit :ohmy:
They are the right fitments etc but the bolt eye at the top of the damper, appears too wide to fit in to the mount on the underbody of the chassis.
Anyone got ANY tips at all before i smash them to bits like a child?? :unsure:
Spent HOURS today trying to get them on but the mount is just too skinny and the eye on the damper (especially the rubber) are too fat to fit together.
The lower eye goes on fine, just the top that is the problem
Beano
  • suzuki jimny fella
24 Apr 2012 19:13 #38520 by suzuki jimny fella
Replied by suzuki jimny fella on topic Re: Fitting Pro Comp Dampers HELP!
trim the rubber down matey and insert sorted B)
  • Beano
24 Apr 2012 19:15 #38521 by Beano
Replied by Beano on topic Re: Fitting Pro Comp Dampers HELP!
Is that ok to do? it wont compromise the strength?
  • Beano
24 Apr 2012 19:18 #38523 by Beano
oooh, also the body of the damper seems awfully wide! as in... looks like it may hit the springs!
Bad times
24 Apr 2012 19:18 #38524 by suzuki jimny fella
that is what we all had to do fella :( it will be sound then not to loss still try and get a tight fit though
  • Beano
24 Apr 2012 19:19 #38525 by Beano
Thanks for the advice, ill be doing it tomorow AM before work!
Cheers
Beano
Time to create page: 0.166 seconds
