2 inch lift
- 4wheelers
25 Jun 2010 20:26 #3676
by 4wheelers
2 inch lift was created by 4wheelers
Has anyone fitted a 2 inch lift kit from jimny bits? I would like to know what it is like and if you need to fit castor correction and extended brake lines with it as well?
- kevant
26 Jun 2010 05:18 #3677
by kevant
Replied by kevant on topic Re:2 inch lift
i have fitted a rhino ray 2 1/2" kit and i can tell you i would definately say fit an extended brake line kit and castor correction and mine is only 1/2" more than Jimny bits kit.
- Johnniehec
- Thank you received: 56
28 Jun 2010 09:23 #3692
by Johnniehec
Replied by Johnniehec on topic Re:2 inch lift
Yes you will need extended brake hoses and preferably fit them first or at the same time. I did my springs first (2 inch Jimny bits) and needed spring compressors as the brake hoses didn't let the axle drop far enough.
I bought castor correction bushes but haven't fitted them yet and yes they are required, mine currently tends to wander in tramlines etc.
John.
John.
- Johnniehec
28 Jun 2010 09:26 #3693
by Johnniehec
Sorry I should have said Jimnybits did a package through Ebay springs, shocks and bushes after I emailed. I got hoses from Llama.
- alexb25
29 Jun 2010 05:15 #3700
by alexb25
Replied by alexb25 on topic Re:2 inch lift
hi,
I have fitted jimnybits 2" shocks and springs + extended brake lines + adjustable panard arm set. It is OK so far. Of course it is better to fit caster correction, but I haven't.
In the future, if I want 3", caster correction will be a must!
- 4wheelers
08 Aug 2010 09:10 #4127
by 4wheelers
Replied by 4wheelers on topic Re:2 inch lift
Before you fitted the adjustable panhards ware the wheels out of centre by much?
Time to create page: 0.170 seconds
