Auto transmition no drive
- ajs850
02 Apr 2012 13:22 #36759
by ajs850
Auto transmition no drive was created by ajs850
I recentley went wading in my jimny and ended up drowning it managed to get it started but every time i try and set off its like the clutch is slipping and there is no drive?!?
Any ideas?
THanks
Andrew
Any ideas?
THanks
Andrew
02 Apr 2012 15:50 #36778
by Obarno
Replied by Obarno on topic Re: Auto transmition no drive
Did you get water in the auto box? If so you might just be lucky if you completely drain the box AND torque converter, and for good measure change the filter. Unfortunately the smallest amount of water is very bad news for an auto box, the reason is that the water vaporises as it gets hot producing steam, which damages the clutches.
Good luck
Good luck
- X-Eng Simon
03 Apr 2012 07:04 #36805
by X-Eng Simon
Replied by X-Eng Simon on topic Re: Auto transmition no drive
It sounds to me like you've got water in the box. As above, fully drain and change the filter. Fill it with oil and run for a minute or so, selecting each gear in turn on the lever. Stop then leave it over night. Drain a little oil out the bottom. You may see water first then clear oil - in which case just top up. If the oil is emulsified (cloudy pink colour) then empty and repeat the above until you get all the water out.
So long as you deal with the water quickly, it is unlikely to do any lasting harm.
Your symptoms sound like you have emulsified oil between the friction surfaces of the clutches. As above, the friction turns the water to steam and makes the friction surfaces float (a bit like a hovercraft) and not grip.
If you leave it too long, the friction surface rusts which closes the gap between the surfaces and makes all the clutches grip at the same time - effectively selecting all gears simultaneously. This either results in the box jamming or stripping the teeth from the gears - both of which are bad.
Si
Si
- Mumbo Jimbo
04 Apr 2012 11:36 #36910
by Mumbo Jimbo
Replied by Mumbo Jimbo on topic Re: Auto transmition no drive
I've had a similar problem due to water in my auto box, if I put it into drive it would not actually go into gear and pull away. I drained the fluid & refilled and it has been fine since (fingers crossed). It may have shortened the life of the auto box but I'll probably never know, it works now so I'm pretty pleased. I think I'll follow the advice on here and drop the oil pan and replace the filter too along with more fresh fluid.
- ajs850
20 Apr 2012 15:24 #38109
by ajs850
Replied by ajs850 on topic Re: Auto transmition no drive
sorry for the delay in replying just got round to taking it all in bits have cleaned filter up and sump looks fairly clean! How do i get to the torque converter?
Thanks
Andrew
Thanks
Andrew
20 Apr 2012 17:39 #38131
by facade
Replied by facade on topic Re: Auto transmition no drive
You take off the transmission then pull it out of the front of the bell housing
A non starter really.
In The Olden Days there used to be a drain plug on a torque converter, but nowadays oil lasts for millions of miles so you don't drain it every second Saturday.
You can either
fill with fresh fluid, drive a few miles 'till it is hot, drain fluid and refill.
or
you can flush the fluid, this involves filling the transmission, removing the return line from the oil cooler, directing the fluid that comes out into a suitable container and letting it tick over until it pumps out a lire of fluid. Add a litre, and do it again. do this 4 or 5 times.
According to the manual, you will get 1.4 litres in the sump, but 3.5 litres into a dry gearbox
You can either
or
Time to create page: 0.169 seconds
