baleno injectors on jimny engine
- jonplace
26 Mar 2012 18:03 #36407
by jonplace
baleno injectors on jimny engine was created by jonplace
has anyone tried, or read about trying the baleno injectors (green ones) on a jimny engine ?
i've been given a set of green injectors which i appear to be a straight swap fitment ?
i know a couple of people who have replaced jimny engines with baleno engines, the baleno engine runs fine on a standard jimny ecu without any map changes ?
so was wondering about injector changing ?
- zuki andy
27 Mar 2012 09:54 #36435
by zuki andy
Replied by zuki andy on topic Re: baleno injectors on jimny engine
The green injectors are longer than the orange ones. They will fit to the jimny inlet manifold if you use the fuel rail off the baleno, and then modify the black plastic wheel that the throttle cable goes round as it catches on the fuel rail.
Dont know what a 1.3 would run like on green injectors though. A 1.6 on orange injectors runs like a pig, felt slower than a 1.3
- jonplace
27 Mar 2012 13:45 #36454
by jonplace
Replied by jonplace on topic Re: baleno injectors on jimny engine
i've got the whole intake, rail, injectors etc from a baleno
i'm going to try it.
I'm hoping they will flow more fuel for the same injection period and help with low down torque
not sure what the other sensors will make of it or whether it will just run rich
a baleno engine on a standard jimny ecu has much better pick up and runs well
- jonplace
27 Mar 2012 18:29 #36472
by jonplace
Well i tried the baleno injectors tonight and made no difference at all to performance at any rev range, car ran the same so in the end i aired on the side of caution and put the original stock ones back in.
I’m not sure if there are different baleno injectors but the green ones I had were identical in size to the jimny orange ones. It was a straight swap using the existing fuel rail. Easy job. spanish jimny btw.
If i could get the ecu settings alertered (remapped) we may be able to take into consideration the new injectors and adjust the parameters but mapping doesn’t come cheap
Looks like a full baleno or grand vit engine conversion is still the way to go but with only 40k on the clock i'm reluctant to get rid just yet......
- zuki andy
27 Mar 2012 20:22 #36478
by zuki andy
Another difference between Spanish and Japanese built jimnys then.
- MadsV
06 May 2014 10:10 #114305
by MadsV
Replied by MadsV on topic Re: baleno injectors on jimny engine
old thread iknow, but anybody have the Serial number on the green injectors? ia the original red ones are Denso 3260.. it's written on the injector in small writing. or someone has for sale?
Time to create page: 0.508 seconds
