baleno injectors on jimny engine
06 May 2014 11:43 #114306 by Rhinoman
There is no point in running bigger injectors on a stock engine, the ECU will bring the injector pulse width down using the feedback from the O2 sensor, if the fuel trims don't have enough range then it will just run pig rich. The stock injectors have enough overhead to cope with some tuning, the 1.6 injectors are required with the 1.6 engine because it has a different torque curve and you need to 'cheat' the ECU a little because the mapping is wrong.
  • MadsV
06 May 2014 14:23 #114312 by MadsV
Replied by MadsV on topic Re:baleno injectors on jimny engine
Im running a g16b in my jimny, and later on putting a turbo in with piggyback.
  • MadsV
07 May 2014 11:09 #114362 by MadsV
Found it, denso 3290
  • Dave cc
07 May 2014 12:08 #114370 by Dave cc
Replied by Dave cc on topic Re: baleno injectors on jimny engine
Rhinoman wrote: There is no point in running bigger injectors on a stock engine, the ECU will bring the injector pulse width down using the feedback from the O2 sensor, if the fuel trims don't have enough range then it will just run pig rich. The stock injectors have enough overhead to cope with some tuning, the 1.6 injectors are required with the 1.6 engine because it has a different torque curve and you need to 'cheat' the ECU a little because the mapping is wrong.
+ 1 don't waste your time
Time to create page: 0.171 seconds
