engine cut out and wont start again
  • CraigW
16 years 5 months ago - 16 years 5 months ago #3525 by CraigW
engine cut out and wont start again was created by CraigW
urgent help needed i was away off roading at the weekend and i drove around on the afternoon when i got back with no problems what so ever. then when i when out the next day the car did about 3 mile and died no warning it just stopped and now i wont start up again.
the jimny will run on easy start but wont run by itself i have gone through all the plugs and checked there ok it feels like it is not getting any fuel.
also now when i switch the ignition on the engine management light and the car with the pad lock does not show, is this a ecu problem or can any one help with any other ideas
and forgot to mention it is a 2001 reg M13A engine
Last edit: 16 years 5 months ago by CraigW.
  • Jimnychris
12 years 5 months ago #116954 by Jimnychris
Replied by Jimnychris on topic Re:engine cut out and wont start again
Mine is doing the exact same thing right now!!! Cant figure it out at all??? Theres no spark and no fuel feed on mine either??? Mines a 2005 vvt
12 years 5 months ago #116976 by Rhinoman
Sounds like a blown fuse.
  • Jimnychris
12 years 5 months ago #118029 by Jimnychris
Replied by Jimnychris on topic engine cut out and wont start again
Cant believe it, it was a fuse I`d checked several times :(
  • benny
12 years 5 months ago #118032 by benny
Replied by benny on topic engine cut out and wont start again
hi, the ignition key has a chip inside it that works the immobilizer it could prevent the engine from starting if you have a spare key try it :)
12 years 5 months ago #118066 by Rhinoman
if its a key problem then you should get a flashing immo light.
Time to create page: 0.099 seconds
