Sheared all 6 FWH bolts AGAIN !
05 Mar 2012 21:28 #35007 by maverick
have you got those funny pyramid shaped things/washers (they have a slit in them) on the thread, so they go between the FW-Hub and the head of the bolt?
Jalapeño, IISY?
  • Paul4x4
  • Visitor
  • Visitor
06 Mar 2012 14:11 #35039 by Paul4x4
Replied by Paul4x4 on topic Re: Sheared all 6 FWH bolts AGAIN !
I've seen this happening on SJ, Toyota and Nissan axles too. My only theory is that the bolts come loose a little bit, and allow the hub to rotate slightly, and after that the bolts will fail under stress when the hub turns and "hits" against them.
And all of those have happened with manual hubs, so I guess it doesn't matter what kind of hubs you have...
Make sure you have those "cone washers" in place or what ever they are called. And I would also use some thread lock on the bolts to prevent them coming loose.
  • goatboy
  • Visitor
  • Visitor
06 Mar 2012 15:39 #35048 by goatboy
Replied by goatboy on topic Re: Sheared all 6 FWH bolts AGAIN !
Where abouts are they snapping? E.g just the heads snapping off? Any chance you over torque them when installing and weakening them?
  • funkyjimny
  • 2004 jimny soft top, factory hardtop, ARB bumper
06 Mar 2012 21:15 #35070 by funkyjimny
I use studlock and just nip them up really, lost the cone washers a long time ago, but i have been using cap head screws (allen bolt head) which tighten into the taper the washer should use thus securing the hub in position. They shear off level with the wheel hub itself, i.e. there's nothing sticking out when the spacer and FWH are off.
  • g187eev
  • Visitor
  • Visitor
07 Mar 2012 07:50 #35083 by g187eev
Replied by g187eev on topic Re: Sheared all 6 FWH bolts AGAIN !
The cone washer is a key part in preventing them from snapping... as it deflects rather than snapping the bolt.
This is where your problem lies... you need to re-fit all new cone washers, split washers and studs...
RB
  • viciouspenguin
  • Visitor
  • Visitor
07 Mar 2012 09:56 #35088 by viciouspenguin
Replied by viciouspenguin on topic Re: Sheared all 6 FWH bolts AGAIN !
funkyjimny wrote: Had a cracking days laning with the guys yesterday in the Peaks, saw some hard working volunteers repairing a culvert on Stanage , brave men in horizontal snow !
On the way down a very steep lane which we know as 'slippery lane' in 1st
its called bamford clough, and its more fun going up it :p
the snow stopped, just as we were leaving lol.
Time to create page: 0.148 seconds
