Sheared all 6 FWH bolts AGAIN !
- funkyjimny
Topic Author
- Moderator
- 2004 jimny soft top, factory hardtop, ARB bumper
- Thank you received: 56
07 Mar 2012 20:44 #35120
by funkyjimny
Cheers Rob, problems finding them now. sheared both sides off over time and lost all the washers.... I presume nobody manufactures them?
Replied by funkyjimny on topic Re: Sheared all 6 FWH bolts AGAIN !
g187eev wrote: The cone washer is a key part in preventing them from snapping... as it deflects rather than snapping the bolt.
This is where your problem lies... you need to re-fit all new cone washers, split washers and studs...
RB
- Keefe
- Visitor
07 Mar 2012 22:35 #35128
by Keefe
Replied by Keefe on topic Re: Sheared all 6 FWH bolts AGAIN !
Milners used to/do sell them.
I think under the Toyota Surf, iirc.
www.milneroffroad.com/
Rather than search for the cones, ring them and ask.
hth
K
hth
K
- vitara_mad
- Visitor
08 Mar 2012 08:09 #35136
by vitara_mad
Replied by vitara_mad on topic Re: Sheared all 6 FWH bolts AGAIN !
this has happend to me before as well & it did have the cone washers on & as i took the complete front hub off to try drill the bolts out i walked into the garage with it in hand & noticed a complete vitara hub i had in there & had a idea of fitting that in place so i compared the 2 & they are basicly the same so i got on with fitting it on & then got another out of my parts stash & fitted 1 on other side
a few problems solved in 1 go
i did not have the hassle of drilling the broken studs out
no need for spacer rings to fit manual fwh's
no need for special tool to change bearings
no vacume pipes on the hubs
- g187eev
- Visitor
09 Mar 2012 08:16 #35169
by g187eev
Replied by g187eev on topic Re: Sheared all 6 FWH bolts AGAIN !
We stock TG stud kits for toyota fitment... quite likely they are the same as Suzuki.
TG, APR2000 Stud Kit.
"These hub studs are made from the strongest material ARP can manufacture for this type of fastener. ARP 2000 material has a tensile strength of 220,000 PSI and the ARP 2000 hub stud is cadmium plated to ensure that it is protected from rust and corrosion for many rough years to come. On the top of the stud we machined a 6mm hex head so that installation and maintenance is easy and no special tools are required."
They ain't cheep tho...
- funkyjimny
Topic Author
- Moderator
09 Mar 2012 10:03 #35175
by funkyjimny
Cheers for the help guys, on the case now.
Gary
Gary
- Keefe
- Visitor
09 Mar 2012 11:10 #35182
by Keefe
www.milneroffroad.com/index.php?route=pr...er_sub_category=true
Worth a try?
As I said above, ring 'em & see.
Worth a try?
Time to create page: 0.143 seconds
