Small story, big problem!!!
  • Seawolfvarna
02 Mar 2012 21:02 - 02 Mar 2012 21:13 #34690 by Seawolfvarna
Small story, big problem!!! was created by Seawolfvarna
Hi, friends!
I would like to tell you, a little story with big consequences!
Last year (August), I purchased 6.5 : 1 rock crawler. My ambition, was to be able to fit at least 31". I bought the tyres, as well as Lockright locker for my rear axle. Everything have been installed in same time. I drove with new tyres, rock crawler and locker for about 500 miles, tested all together and the only problem was a little disturbing noice from t- box. It looks, that is normal, because of run in time of gears and e.t. I am a seaman. And than , I went to my next contract and returned back home at 23.01.2012. Since that time, I am running my Jimny with all a.m. upgrades with the only problem- still that unpleasant noice which is coming specially when on 4-th gear. Any way, there is an upcoming offroad competition in Bulgaria and I decide to participate. Because , it is in two stages - long one 70 km and short enclose one, trial, I decide to purchase also suitable tyres for the long one stage. So, I purchased BFGOODRIDGE Mud terrain km2 tyres-215/75/15. After received the new tyres, I decided to test them. And than comes the trouble! On first slop with a lot of mud, my brand new rock crawler T-box, when fill a little bit tension, automatically switch off to neutral(free) position. After that was not possible to put any other direction and my Jimny remain totally dead. After small consult with Mr.Butler, he send me complete instruction, how to dismantle and inspect the T-box. So we did it. We found only one bearing slightly damaged( output to rear axle) and there was not enough clearance between speedo gear and distance bush close to it. Nothing ese was wrong, nothing damaged found, but the T- box was jumping to neutral position and was remaining blocked in that position. So today, we assemble again everything back and I made a test run. Still that disturbing notice, especially when on 4-th gear, was present, but not so loud as before. But unfortunately, again on first slop with a lot of mud, running on 1-st gear on 4 H, again my T- box jump to free position and totally stuck. Then my mechanic came and adjust the lever and together we tried and again and again, when fill a little stronger tension, my Almost new T-box was jumping in neutral free position(typical for Samuraj T-box).
So, considering the following facts:
- fitted new tyres 215/75/15( before with 31" , that problem never happened )
- fitted Richmond Lockright Locker on rear axle.
Why, this is happening? Why my 6.5 :1 rock crawler box is jumping to neutral position? My bigger concern is, that if I can not fix the t-box, than I order for nothing, brand new 4.5" suspension kit from O.R.A.
Please, if anyone, have ay experience to suggest some solution? Presently, I am planning now to fix again my big 31" tyres and to test again with them the t-box in order to check if the problem will be same with them or not. Next step will be again complete dismantling of t- box and trying to find the reason for that jumping under tension to neutral(free) position of t-box lever.
Thank you in advance!
With best regards :
Nick from Bulgaria
Last edit: 02 Mar 2012 21:13 by Seawolfvarna.
  • Seawolfvarna
03 Mar 2012 14:47 #34723 by Seawolfvarna
Replied by Seawolfvarna on topic Re: Small story, big problem!!!
Today, I fit my 31" tyres and unfortunately after the test, result is same. Presently I am fitting my old original T-case and the crawler will be completely dismantled and inspected once again.
My concern is also if the problem can be connected with already fitted locker on rear axle?
  • bluejimny
03 Mar 2012 15:49 #34727 by bluejimny
Replied by bluejimny on topic Re: Small story, big problem!!!
i must admit i've had a similar problem with mine, i will be driving along in 2wd and the sj box will jump into Neutral i would be able to get drive again, but would only be able to get 2 H and 2 L
its not been a problem as i have a twisted shifter that allows me to select all the 2 H , 2 L 4 H and 4 L but i also have a locker!
it only seems to jump out when going round a corner under slight power making me think the locker is jerking when locking up causing the box to jump into N
but it never jumps out in 4wd H or L it only jumps out in 2 H :blink: :blink:
03 Mar 2012 19:05 #34751 by funkyjimny
Whereas mine jumps out of 4H, never a problem in 2H or 4L or 2L.... I have a 6:1 and a lockright locker.
The following user(s) said Thank You: Seawolfvarna
  • Seawolfvarna
03 Mar 2012 19:20 #34755 by Seawolfvarna
When on 4H, my is jumping to neutral free position. When I am running on road with 2 H , it is trying to jump again, but most probably, because of not so big load , just trying. Is a nobody know, how we can eliminate that jumping problem? Why that is happening? My next step after inspecting the crawler will be to remove to locker and to fix back factory rear axle and if then again the problem exist, that will only mean, that is something wrong with that t-case, but not mechanically, but only mathematic. What is the bigger tyre which can be normally run with original t- case?
  • Seawolfvarna
04 Mar 2012 19:38 #34844 by Seawolfvarna
Looks like, I am not the only one, who have the same problem.
Please, if somebody, have some observation and discover something, which can solve the problem, please share your experience? As soon as, I inspect t- box again, I am going to remove the locker and then I will fix and test the crawler again.
Best regards:
Nick
Time to create page: 0.251 seconds
