k&n filter
  • Jeffskowski
23 Feb 2012 08:27 #34061 by Jeffskowski
Replied by Jeffskowski on topic Re: k&n filter
ZookFastback wrote: Anyone considering fitting a K & N Filter should check out this site first... www.bobistheoilguy.com/airfilter/airtest1.htm and if you already have one of those filters, toss it out and spend the money on a quality paper filter.
:sick:
In 20 years of motoring I have never seen any damage of engine components or running issues when using serviceable air filters. From VW beetles with HiPo engines to the modern daily run around, I have always used them and not once have I had an issue.
It's entirely up to the driver what they choose of course but this is my experience.
There is a lot of test data out there for every single thing that has ever been produced. Lots of positive and lots of negative. I am not disagreeing with what Oily Bob is saying in his testing but it is just one opinion.
23 Feb 2012 09:11 #34065 by Obarno
Replied by Obarno on topic Re: k&n filter
Very interesting article and some valid points made. I imagine also that how you use the car makes a huge difference. If its mainly road use perhaps a K & N is fine, but if it's off road a lot on dusty tracks then an original equipment would seem to be better. I know from my experience of tracks in the summer in France dust is a real problem, and obviously the same in Oz. It's quite easy to make a filter clogged with dirt in a day out, and that's with a snorkel facing backwards as well.
  • stu44
23 Feb 2012 11:38 #34067 by stu44
Replied by stu44 on topic Re: k&n filter
i have a k&n panel filter on my jimny and i have found i get approx 10 mpg better,hope this helps
  • SUGAR DELTA
23 Feb 2012 12:00 #34069 by SUGAR DELTA
Replied by SUGAR DELTA on topic Re: k&n filter
Some interesting and conflicting views here,I think for the price and seeing as I won't be doing many dusty trails I will go for it and give it a try.
Thanks to all that replied !
23 Feb 2012 16:04 #34076 by facade
Replied by facade on topic Re: k&n filter
stu44 wrote: i have a k&n panel filter on my jimny and i have found i get approx 10 mpg better,hope this helps
What 40 + with a K&N?
I'm gonna fit 3 then, I want 60MPG ;)
  • darthloachie
23 Feb 2012 16:10 #34077 by darthloachie
Replied by darthloachie on topic Re: k&n filter
I have two fitted but still only get 20-25mpg :unsure:
Time to create page: 0.164 seconds
