why is this happing? (Spring lift baned)
- Nivo
- Visitor
07 Feb 2012 18:13 #32936
by Nivo
why is this happing? (Spring lift baned) was created by Nivo
- jimny5
- Visitor
07 Feb 2012 18:41 #32939
by jimny5
Replied by jimny5 on topic Re: why is this happing? (Spring lift baned)
thats what happens when you have longer springs with standard arms,
- Nivo
- Visitor
07 Feb 2012 18:49 #32944
by Nivo
Replied by Nivo on topic Re: why is this happing? (Spring lift baned)
so what can i do to fix this?
oh and by the way. im runin without stablizer arm
- funkyjimny
- Moderator
- 2004 jimny soft top, factory hardtop, ARB bumper
- Thank you received: 56
07 Feb 2012 18:52 #32945
by funkyjimny
Replied by funkyjimny on topic Re: why is this happing? (Spring lift baned)
1)you need castor corrected radius arms
2)axle seems to be going over to one side too, when you lift your car you need to adjust the length of the panhard rods to suit so buy a pair of adjustable panhards for the front and rear
Try either ORA or jimnybits.co.uk
Gary
Gary
- supergaz
- Visitor
07 Feb 2012 19:35 #32949
by supergaz
Replied by supergaz on topic Re: why is this happing? (Spring lift baned)
Also don't forget with extra downwards travel you will need longer brake lines.
- bluejimny
- Visitor
07 Feb 2012 19:49 #32951
by bluejimny
Replied by bluejimny on topic Re: why is this happing? (Spring lift baned)
the trailmaster shocks are only slightly longer than standard hence no need for longer hoses
