why is this happing? (Spring lift baned)
07 Feb 2012 23:45 #32986 by funkyjimny
castor bushes are fine for 2" lift, anything more and you really need new radius arms.
Gary
  • Nivo
  • Visitor
  • Visitor
08 Feb 2012 06:04 #32991 by Nivo
ok good to know!
i'll search in sale :)
by the way. i need the hole 4 radios arm? or i can change only the front two?
08 Feb 2012 09:25 #33004 by funkyjimny
You can get away with changing just the front radius arms, best to get some Bigjimny lower rear shock brackets for the rear axle, saves the bushes wearing out in 5 minutes.
Gary
  • Nivo
  • Visitor
  • Visitor
09 Feb 2012 20:31 #33161 by Nivo
so basicly. i need two front radios arm caster correction
and lower rear shock brackets for the rear axle? that will work out my problem?
  • supergaz
  • Visitor
  • Visitor
09 Feb 2012 20:48 #33163 by supergaz
Replied by supergaz on topic Re: why is this happing? (Spring lift baned)
Yes, castor correction bushes and rear shock brackets.
  • Dutchjimny
  • Visitor
  • Visitor
09 Feb 2012 21:00 #33167 by Dutchjimny
Replied by Dutchjimny on topic Re: why is this happing? (Spring lift baned)
do you need those rear shock brackets with corrected radiusarms at the rear?
Time to create page: 0.160 seconds
