Rear driveshaft advice
- Jimbo in the Jungle
05 Feb 2012 09:18 #32689
by Jimbo in the Jungle
Rear driveshaft advice was created by Jimbo in the Jungle
I am confused... the rear driveshaft on my Jimny does not look quite like I expected.
From the manual I was expecting there to be a splined shaft that I can access, but mine has a rubber boot that does not look like it is an original part. When I stick my fingers under the boot I can feel some wire that has been used to fasten something.
Does the splined shaft normally pull apart easily? Any idea what the wire could be 'fixing'?
Thanks,
Jim.
Thanks,
Jim.
05 Feb 2012 10:11 #32695
by facade
Replied by facade on topic Re: Rear driveshaft advice
The transfer box end (front) of the rear driveshaft is a CV joint, you might call it a Rzeppa joint, there are ball bearings in grooves under the rubber boot, the joint can pivot and slide in and out. This needs no maintenance, unless the boot is damaged.
The front diveshaft has a sliding splined joint that needs greasing regularly
05 Feb 2012 11:00 #32712
by kirkynut
It's not on any I've seen, it's a UJ. There's a rubber boot to protect the splines where the rear propshaft splits and to keep the grease in.
We are talking propshafts and Jimnys aren't we? Definitely not a Vitara, Sidekick, Tracker?
Replied by kirkynut on topic Re: Rear driveshaft advice
facade wrote: The transfer box end (front) of the rear driveshaft is a CV joint, you might call it a Rzeppa joint, there are ball bearings in grooves under the rubber boot, the joint can pivot and slide in and out. This needs no maintenance, unless the boot is damaged.
05 Feb 2012 11:22 #32719
Replied by Jimbo in the Jungle on topic Re: Rear driveshaft advice
It does look like a CV joint at the front end of the driveshaft. The boot is in quite poor condition and probably needs replacing to protect the CV joint. I can't see any splined shaft that I can pull apart.
Inside the boot there is some thick wire that is twisted around the shaft - I'm not sure what it is there for. Around here most things are fixed with a hammer, so I'm not entirely surprised to find it has been 'fixed'.
Just wondering whether to try and fix it now or just put it all back together and hope for the best...
Jim.
Jim.
05 Feb 2012 13:47 #32729
by facade
Looks like that is a replacement boot from a front wheel.
Here is what it should look like, sorry about the poor focus, we are surrounded by melting snow so I took it one handed from the side.
Attachment rearprop.jpg not found
05 Feb 2012 13:51 #32730
Replied by mlines on topic Re: Rear driveshaft advice
Yep, looks like its had a wheel boot fitted. Perhaps its one of those boots from a cheap Ebay Front CV Joint kit that the supplier couldn't explain to me how it fits a Jimny (it doesn't, the Front CVs are internal to the swivel not external as in the kits he was trying to sell)
Time to create page: 0.106 seconds
