Gearbox Drain Plug Key - what size
17 Apr 2010 15:11 #3147 by maverick
per title - what size Plug Key do i need?
Jalapeño, IISY?
17 Apr 2010 18:04 #3149 by kirkynut
3/4 inch ratchet with no socket on!
Not 100% snug in there but about the best you can do as far as I could see. If it rounds off, get a new one from Suzuki dealers for stupid money and set to it with a chisel to knock it round.
18 Apr 2010 15:39 #3153 by maverick
Bought a 3/8" Drain Plug Key ... Man is that on tight!!!
Me thinks I'm taking it to local/friendly garage tomorrow, and getting them to undo it, and replace oil ... also asking them to fit a decent Drain Plug - one with a head on the OUTSIDE!!
Jalapeño, IISY?
18 Apr 2010 18:46 #3163 by kirkynut
I've known people to have to weld a nut on before in order to get them out.
I could not get my filler plug off and had it in mole grps, filed flats to the sides to grip to, knocked it with a cold chisel. The mole grips got it in the end but after a long time wearing an generally mucking about with it.
Make sure you have a new plug before you get the old one removed or you'll not be able to drive it!!! Don't count on your local dealer having one in stock either, mine didn't.
19 Apr 2010 05:59 #3174 by maverick
Its at my local/friendly garage ... what with a ramp and air-tools - they should have a better chance!!
Jalapeño, IISY?
21 Apr 2010 15:36 #3209 by maverick
Jimny is back from the garage - Jeez they were not happy!!
They told me (when i went to pay) that had a b1tch of a time removing the drain plug to change the Gearbox oil for me... and they have air tools and a ramp!!
They've kindly re-fitted it with copper-slip to aid removal next time ...
They also said that it might be a good idea to get a new Drain Plug as the in-sides are awful -- maybe me (LOL) -- when i was underneath attempting to get it out!!??
I've contacted my local Suzuki-stealership (Wallasey - 5miles away) - a NEW replacement is just £7.... it should be here on Friday!!
Jalapeño, IISY?
