Gearbox Drain Plug Key - what size
  • bryandenham
29 Apr 2010 16:31 #3279 by bryandenham
Replied by bryandenham on topic Re:Gearbox Drain Plug Key - what size
just a little tip. try and remove the FILLER plug first cos otherwise you can be really stuck.
I've got an access door in the side of my transmission tunnel now and 17mm hexagon headed plugs, (i drilled a hole in the existing plugs and welded in a couple of bolts!)
To get the old plugs out I had to drill a hole in them and then knock in a tapered square bar with a tee bar on.
I'm after a two inch spring kit. Any body got one cos pro-comp seem to have stopped trading.
all the best from the Isle of Man. Bryan D
29 Apr 2010 17:16 #3280 by kirkynut
KAP and Rhino Ray do them too!
01 May 2010 17:02 #3290 by maverick
got a new one from local SuzukiStealership - only £7
Jalapeño, IISY?
Time to create page: 0.371 seconds
