stereo problems
  • daniel
08 Jan 2012 11:51 #30243 by daniel
stereo problems was created by daniel
hi
ok im not a stereo nut, just standard unit is fine but mine has ,AM working fine and FM doenst work nomatter how long i play with it ,i put a new aerial in but no change ..so i decided to get a new unit but im not sure if a standard unit will fit ? i googled it and it says doudle DIN . im thinking DIN is standard . my current unit is factory standard , so will my dash except any standard unit ??just wanna be sure b4 i start ebaying.....thanks
  • darthloachie
08 Jan 2012 12:06 #30247 by darthloachie
Replied by darthloachie on topic Re: stereo problems
double din is twice the normal stereo size
you can get an adapter plate to fit a standard head unit
you will also need an adapter harness
try the suzuki breakers such as cam-suzuki (they are on ebay - search for breaking suzuki) and you should be able to get a second hand replacement one
  • little jimny
08 Jan 2012 19:00 #30293 by little jimny
Replied by little jimny on topic Re: stereo problems
It depends on how old your Jimny is, but to put it in simple terms if your Jimny has the four spoke steering wheel the setero is a standard DIN fitting, but if yours has the three spoke steering wheel it will be double DIN (that's assuming the steering wheel you have is the one fitted by the factory!)
  • Adamski
08 Jan 2012 23:33 - 08 Jan 2012 23:34 #30328 by Adamski
Replied by Adamski on topic Re: stereo problems
Mine is a 2002 and takes a single din as standard however I've removed the clock/storage bin and fitted a double din by customising the brackets which came with the 2 din head unit (I didn't need to use a cage).
Last edit: 08 Jan 2012 23:34 by Adamski.
  • daniel
10 Jan 2012 11:39 #30460 by daniel
Replied by daniel on topic Re: stereo problems
hey thanks for the replies i got it all worked out now , but wouldnt ya know it was driving today and battery light came on and i though it was because i been flooging the a/c and draining battery , so i turned a/c off and kept driving keeping an eye on battery light ,then i was stopped at red light and engine was chugging and i noticed little bit of steam i looked at temp and it was maxed out ,i turned engine off caused a big peak hour hold up and two kids helped me get it off the road when i opened the bonnet the alt belt was not there lol must of snapped , any way 2 hrs later after working out i had to take the other belt off to put new one on it was all ok except screeching tight belt but ill deal with that tomorrow iv had enough of today ...thanks for the stereo advise ill buy a cheapie on ebay next week and be confident it will fit .
