Odd behaviour on tickover and acceleration.
27 Dec 2011 19:36 #29319 by Foxtrot
Hi Rob, I'm not sure if this will help but this thread shows where the crank/cam shaft sensors are, these too can cause problems
www.bigjimny.com/index.php?option=com_ku...mitstart=6&Itemid=75
  • Rob Edge
28 Dec 2011 12:48 #29364 by Rob Edge
It's the IAC valve sitting beneath the throttle body that is at fault. When I disconnect it the tickover rises to 1400rpm but is stable. When I reconnect it I get the odd rise and fall for about a minute then it falls to 700 without a blip. IAC valve is likely to be sticky but it does say it needs a new gasket if removed. Anyone ever removed it successfully without a new gasket?
  • Rob Edge
12 Jan 2012 19:09 #30764 by Rob Edge
Looks like I finally got it nailed. Changed the engine coolant temp sensor today and bingo, problem gone. It cost £43 from Suzuki which is a bit steep.
Time to create page: 1.316 seconds
