jimny running problem
28 Mar 2010 19:18 #2913
Replied by mlines on topic Re:jimny running problem
At a quick count in my parts list I can see 3 ECUs listed for the single cam engine and (so far) 15 ECUs for the Twin Cam Engine.
- petetong
28 Mar 2010 20:53 #2918
by petetong
Replied by petetong on topic Re:jimny running problem
so if i was to get the numbers of the ECU could you tell me if i got the right one?
29 Mar 2010 05:36 #2921
If you give me the part numbers and the VIN number I can look them up, no guarantees as the Suzuki system does not have every vehicle on it.
30 Mar 2010 17:33 #2968
Ok - based on the info you PM'd me......
It should be:
Cyprus Blue Metallic (Z2J colour code)
Engine Number G13BBXXXXXXX
Model Code: MRKXXXXXX
5-Speed Manual without Air Bags, E02 Specification
The ECU on this one should be 33920-81A11 (which looks like the number you found!)
It should be fitted with a 33970-70F01 Immobiliser which must be paired with the ECU - there is a procedure to do this in the workshop manual pg8G-19 which I could reproduce here, but you need a Suzuki SCAN TOOL to reset the matching codes
I will post this reply to your other threads for the information of others but will hide the serial numbers for your car
It should be:
- petetong
30 Mar 2010 18:14 #2969
by petetong
ok.. thanks for that(and thianks for your other reply to..top man!)
so things are'nt looking to good at the mo..
so am i better of seeing if i can get the immobiliser box and key from this jimny that i got the ecu from,as well?
should i be able to plug them all in and away she goes?!!
30 Mar 2010 18:21 #2970
No problem
If you get a matched set of key,immobiliser and ECU then it should work.
ALternatively, Rhinoman on Difflock may know how to match up the ECU and immobiliser as he has been decoding the ECU programming
Time to create page: 0.207 seconds
