jimny running problem
  • petetong
27 Mar 2010 17:46 #2886 by petetong
jimny running problem was created by petetong
hi all.. some of you might know of me??
well i been out and got a nice cheap little jimny :)
BUT its cheap cos its got a little problem! well 2 really.. very light front end damage.. which i have already repaired..
and a bit of a running fault!
the bloke i got it off said it was towed to a garage after and thay said it was n ECU fault.. so a second hand replacement was fitted(so i was told??!!) but still it want rev..
it will start from cold.. run very lumpy.. then after about 30 seconds it cuts out then will be very had to start,and only with full throttle??
with out going to much in to it..
i have checked everything.. got fuel, spark, and timing is all ok..
no engine light on.. other than if you unplug a sensor.. like the temp one.. which helps..a bit in its trying! to start!!
now when you pull the plugs out(and i even pulled the lambda out to have a look) there BLACK! its proper over fueling?!!
massively over fueling..
but why?? im guessing that the ECU is keeping the duration of the injectors open to long?? but way??
please some one help!
its to nice little truck to give up on.. and i really don't want to have to stick the bike carbs i got kicking around on it! :huh: ;)
not only the that. but want it to get back out in the mud again, after a little spell away :lol:
27 Mar 2010 18:21 #2889 by mlines
Replied by mlines on topic Re:jimny running problem
Could it be the Lambda sensor?? or perhaps the camshaft sensor or a blocked catalytic converter (has the cat collapsed in the minor shunt that bent the front end?
  • petetong
27 Mar 2010 19:31 #2891 by petetong
Replied by petetong on topic Re:jimny running problem
none of the above :(
changed the lambda, camshaft sensor must be working as im getting spark.. and would have thought that if it was putting the timing out.. it would be popping of/backfire thought either the inlet or exhaust.. but its not..
one of the first things i did was drop the system of down from the exhaust manifold to see if was a blocked cat.. and it made no difference!! :blush:
im shore its fueling.. but why??!
  • kevant
27 Mar 2010 22:32 #2893 by kevant
Replied by kevant on topic Re:jimny running problem
It might be a long shot but have you checked all your earthing points sometimes electrical and running probs are just a bad earth (does sound like ECU though)
  • petetong
28 Mar 2010 09:22 #2896 by petetong
yeap.. done all that.. im going to look bit more in to the fuel pressure side of it.. as im telling myself!!!!! that it can't be ECU as im getting spark and fuel.. if it was an ECU fault.. don't think?? i would either?or at least. one or the other??
  • petetong
28 Mar 2010 19:08 #2909 by petetong
well i have now replaced nearly everything fuel side!
and still its massively over fueled!!
what would be doing this?? if you crank it from cold.. it will start. then run lumpy and then cut out!!pull the plugs out and there sopping wet!!
i was told that the ECU was from an 16v single cam jimny.. but im wondering.that maybe it from the twin cam lump..
so my next question is.if it is.. would it fit/work on the earlier single cam engine?
if so might this be why its over fueling?!!
