axle oil level ????
- suzuki jimny fella
15 Dec 2011 16:52 #28247
by suzuki jimny fella
axle oil level ???? was created by suzuki jimny fella
can eny one tell me if the level of my oil in the front axle is when it come out of filler hole or do it have to be 1.1L done my king pin bearing to day so thougt i would change diff oil
but it took 1.6L see many thanks if you can help me thanks boys
15 Dec 2011 17:04 #28252
by kirkynut
Replied by kirkynut on topic Re: axle oil level ????
It's till it comes out the filler hole.
15 Dec 2011 17:09 #28254
Replied by suzuki jimny fella on topic Re: axle oil level ????
but it says 1.1l in book but i have allways filled diff till it comes out of filler hole way do thay say 1.1L for strange
15 Dec 2011 17:24 #28258
by kirkynut
Is it parked on the level?
Otherwise don't worry about it. If it's up to the filler so it just overspills when the plug is removed, it has enough in it. That's the main thing.
I don't use books as bibles, just as guides. I've often put in more/less coolant or oil in cars than books say and gave up measuring.
I recently changed the radiator in my Micra and had not long renued the coolant, so dropped it and caught every last drop. In theory I would not need to put more or less in but it took more. The level's stayed the same for a month or so now without using any so I'll not worry.
The following user(s) said Thank You: suzuki jimny fella
15 Dec 2011 17:40 #28264
as long as it comes out of the hole it be ok yer what about tbox and gearbox to it say 1.1Lgearboxs and 0.8L in tbox so if it goes over the 1.1L and 0.8L it will be ok will not get eny drag in gear change etc as i am doing them in the morning thanks
15 Dec 2011 19:22 #28293
by kirkynut
Just make sure it comes out the filler hole and all will be well.
