axle oil level ????
  • wanderinstar
16 Dec 2011 11:31 #28340 by wanderinstar
Replied by wanderinstar on topic Re: axle oil level ????
Do as kirkynut says.
Mind you, in my Suzuki manaul it says,
1.3l in gearbox,
0.9l in transferbox,
1.35l in front diff and 1.5l in rear diff.
How did you go on getting outer bearings out of swivel unit.Did you put some weld in as Martin suggested in his "How too guide"?
Ian.
  • Cocopolo
16 Dec 2011 14:00 #28354 by Cocopolo
Replied by Cocopolo on topic Re: axle oil level ????
If your jimny is lifted, without any correction of front caster, the diff housing horientation is "looking at the pavement", hence the quantity of oil which can be filled inside is less than 1.35 ltrs ...
same for rear axle ...
  • suzuki jimny fella
16 Dec 2011 16:07 #28370 by suzuki jimny fella
Replied by suzuki jimny fella on topic Re: axle oil level ????
thay fell out thay where bust:( glad that thay are done now thow :laugh:
so dont fill gearbox and tbox till it comes out of the filler hole i take it boys just 1.3 and 0.9 in them
16 Dec 2011 17:41 #28382 by fast forward
good question i await the answer also ! :dry:
if you cant go round it go over it ! or vice versa ?
16 Dec 2011 20:24 #28395 by suzuki jimny fella
can enyone help me with my question thanks
Time to create page: 0.186 seconds
