winch battery??
- supergaz
15 Dec 2011 16:07 #28242
by supergaz
Replied by supergaz on topic Re: winch battery??
I got a big truck battery, they are cheap and have tons of power. I got a 190amp for £100. But it is the size of the boot! Maybe I should have got a Yellow top just for the smaller size but bigger price tag!.
15 Dec 2011 17:09 #28253
by kirkynut
Replied by kirkynut on topic Re: winch battery??
I'd still by a battery made for th job, even though you don't intend on using the winc much. The Jimny battery is puny and will be ruined by winching, so you'll end up buying another one of them and be spending just as much as if you'd just bought the right one fro the job in the first place. A false economy.
- myers647
15 Dec 2011 18:53 #28285
by myers647
Replied by myers647 on topic Re: winch battery??
No eBay APP ID and/or Cert ID defined in Kunena configurationHi would this be suitable???
thanks
james
thanks
james
15 Dec 2011 19:19 #28291
by kirkynut
Looks to be, the spec of my Numax is below:
Voltage: 12 Volts
Capacity: 86 Ah
CCA: 1000 A
Length: 257 mm
Width: 172 mm
Height: 220 mm
The only thing is - £50.00 for a second hand battery that is about £150.00 new - makes me wary!
Voltage: 12 Volts
Capacity: 86 Ah
CCA: 1000 A
Length: 257 mm
Width: 172 mm
Height: 220 mm
- wanderinstar
16 Dec 2011 11:46 #28344
by wanderinstar
Replied by wanderinstar on topic Re: winch battery??
I have a Bosch Silver S4 72ah 680ah that ipaid about £95 for a couple of years ago.I was for a Saab 3.0 V6 diesel I intend fitting that on the n/side inner wing.
16 Dec 2011 16:49 #28375
by Obarno
Replied by Obarno on topic Re: winch battery??
If you want to buy a battery that will fit in the original place on your Jimny then this could be the answer
www.tayna.co.uk/Optima-Yellow-Top-YT-S-2.7J-P3803.html
For your relatively small winch, but quite ok for a Jimny, then this will be fine. With my VVT Jimny I have the original battery and a Superwinch EP9 and it seems to work ok for occasional winching. For competition use, as Kirkynut says, a bigger battery would be better. The disadvantage, for me anyway, is that the car has ABS so its not possible to fit a bigger battery on the other side of the engine compartmant, and I don't want it inside the car as its small enough inside without a big battery in the back as well!
So at some point I will buy one of these yellow tops.
For my auto I have a Jeep Wrangler battery on the other side of the engine bay which is high output but not too tall. Can't remember exactly what it is now, but its not as high as the Numax, but quite ok.
Time to create page: 0.192 seconds
