2-good tyresplus 2-partworns
  • wanderinstar
14 years 11 months ago - 14 years 11 months ago #27952 by wanderinstar
2-good tyresplus 2-partworns was created by wanderinstar
Yesterday i was given the above Colways.My question is where do I fit them on the vehicle.Don't anyone say "on the hubs" :laugh:
Do I put the good tyres on the front to pull the vehicle over obstacles or on the rear to push over obstacles.
Alternative;y do I mix them on each axle, to avoid spring wind-up.The thinking being that with no centre diff there would be a differing rolling radius on each axle.
Ian.
Last edit: 14 years 11 months ago by wanderinstar.
  • darthloachie
14 years 11 months ago #27958 by darthloachie
Replied by darthloachie on topic Re: 2-good tyresplus 2-partworns
I would put the good ones on the back to prevent lift off oversteer on the road
If you are in 4wd then the surface should be mud or snow - ie slippy so you shouldn't get wind up and better grip at the back to push
  • mcjimny
14 years 11 months ago #27963 by mcjimny
Replied by mcjimny on topic Re: 2-good tyresplus 2-partworns
What tread are they? if they're the old colway mt's then they are the same pattern as technic trackers iirc. Just if you wanted to get some better ones to replace the part worns.
  • supergaz
14 years 11 months ago #27964 by supergaz
Replied by supergaz on topic Re: 2-good tyresplus 2-partworns
I've used the better ones on the front in the past and know they are well balanced, I've not tried it the other way around.
Time to create page: 0.085 seconds
