Rear axle ??
  • Gromit
11 Dec 2011 12:34 #27856 by Gromit
Rear axle ?? was created by Gromit
Quick question, did the rear axle on Jimnys change at all between 1999 & 2002 as I have the chance of a 2000 one for my 2002 model which has just about had it ?
11 Dec 2011 14:35 #27866 by mlines
Replied by mlines on topic Re: Rear axle ??
Do you mean axle or do you mean diff?
If you mean axle then as long as you get an ABS or non-ABS one as is appropriate to your needs then you will be ok.
If you mean diff, then you need to watch out for auto or manual as the diff ratios vary
  • Gromit
11 Dec 2011 15:12 #27875 by Gromit
Replied by Gromit on topic Re: Rear axle ??
It's a full axle Martin, non-abs and manual box same as mine, just 2 years older than mine so should be ok then .
  • Gromit
11 Dec 2011 20:21 #27921 by Gromit
I'm presuming that my rear diff is knackered as I get clunking from the rear end when setting off or changing gear, could it be anything else Martin.
  • reaper
11 Dec 2011 20:23 - 11 Dec 2011 20:24 #27923 by reaper
Replied by reaper on topic Re: Rear axle ??
have you seen the one on evilbay ?
cam suzuki want 360 or so for one but there is one on for 100 buy it now
Last edit: 11 Dec 2011 20:24 by reaper.
  • Gromit
11 Dec 2011 20:30 #27927 by Gromit
reaper wrote: have you seen the one on evilbay ?
Yep seen that one, just trying to be sure that it is the diff thats goosed !!!
