Horn doesn't work
  • Rob Edge
10 Dec 2011 20:58 #27830 by Rob Edge
Horn doesn't work was created by Rob Edge
A recent as in today convert to the Jimny I would appreciate some help. The black wire is going to ground and the white is dead. I have tried a separate earth and positive to the horn and it works.
  • reaper
10 Dec 2011 21:16 - 10 Dec 2011 21:17 #27831 by reaper
Replied by reaper on topic Re: Horn doesn't work
checked fuse and relay ?
if they both check out check for continuity along the white wire
Last edit: 10 Dec 2011 21:17 by reaper.
  • Rob Edge
10 Dec 2011 21:33 #27833 by Rob Edge
Replied by Rob Edge on topic Re: Horn doesn't work
Fuse is ok but I don't know were the relay is to check it. Any ideas.
  • p1ngu32
10 Dec 2011 22:23 #27838 by p1ngu32
Replied by p1ngu32 on topic Re: Horn doesn't work
Dont know if there would be a horn relay? Could be the switch itself thats going or a loose wire. remove the steering column cover and put a tester on either end of the horn wire and see if you are getting a connection. If you are then you will need to test the switch.
  • Rob Edge
11 Dec 2011 13:33 #27858 by Rob Edge
Got to the bottom of it. The relay is on the loom under the column behind the fusebox. Little black box about 2x2x1cm. It wasn't that anyway. The slip ring behind the steering wheel is fubar.
Time to create page: 0.169 seconds
