King Pins renewal
  • wanderinstar
08 Dec 2011 08:58 #27525 by wanderinstar
King Pins renewal was created by wanderinstar
Is kingpins a misnomer? I called in at BCC Suzuki in Blackburn and was told to check kinpins as they were a recognised problem on Jimny's.He also said that it was a £400 job. On doing a bit of researchI see that kingpin BEARINGS and SHIMS are available. Is this what "goes".If so it is hardly £400 to replace them, surely?
Ian.
08 Dec 2011 09:02 #27526 by mlines
Replied by mlines on topic Re: King Pins renewal
Suzuki always replace both the Kingpins and the Bearings at the same time and then charge on top of that their value for money prices!!
However, 99% of the time you can get away with just changing the Bearings for £23.50 per side.
  • wanderinstar
08 Dec 2011 09:10 #27529 by wanderinstar
Replied by wanderinstar on topic Re: King Pins renewal
Thank you for that Martin.I was thinking back to A55 Cambridge dat.When you had an actual pin and bronze bushes you had to press in and then ream out. Couldn't imagine how that system worked with front wheel drive.
08 Dec 2011 16:11 - 08 Dec 2011 16:13 #27543 by facade
Replied by facade on topic Re: King Pins renewal
The jimny has swivel bearings not kingpins, but in the face of a majority who call them kingpins, I eventually conceded defeat and went with the flow. :side:
Now the MGB in the garage has kingpins, another excellent Austin design, use a screw thread as a bearing at the bottom.:blink:
Last edit: 08 Dec 2011 16:13 by facade.
  • wanderinstar
08 Dec 2011 16:19 #27546 by wanderinstar
ahh, now your talking my language.Same as the Minor.That had the trunnions at the bottom. IIRC at the top as well. Those were the days. Am I showing my age now.
  • darthloachie
08 Dec 2011 16:48 #27549 by darthloachie
Replied by darthloachie on topic Re: King Pins renewal
yep :laugh:
i had a moggy traveller and a MG Midget both with the same fabulous suspension design and monthly nipple greasing
with a set of crossplys you could drift across wet roundabouts at 20 mph B)
Time to create page: 0.164 seconds
