Front seat belts on 03 Jimny.
  • zaine
06 Dec 2011 11:34 #27367 by zaine
Replied by zaine on topic Re: Front seat belts on 03 Jimny.
Halford wrote: yeh, my 2007 belts are just as bad :(
check where they slide into the upper guide, the lips on mine were black and sticky - scraped it off and squirted with silicon, def helped for a while ...... has just reminded me to do it again ;)
ps. welcome to the forum
i did this
then got fed up and put some 2010 ones in, done :)
  • VAXXi
06 Dec 2011 12:46 #27373 by VAXXi
Replied by VAXXi on topic Re: Front seat belts on 03 Jimny.
What's the difference between 2010 and 2007 ? did they change anything in the belts' construction ?
06 Dec 2011 16:34 - 07 Dec 2011 06:25 #27380 by Halford
:woohoo: hope there's been some fix, with better 2010 ones
do they have a different design then zaine :dry:
Last edit: 07 Dec 2011 06:25 by Halford.
  • adamatdraycott
07 Dec 2011 11:58 - 07 Dec 2011 12:16 #27464 by adamatdraycott
Replied by adamatdraycott on topic Re: Front seat belts on 03 Jimny.
The amount of times i've had passengers almost shut the end in the door!
Mine even got an advisory on its MOT when the previous owner had it!
If the new belts are better, i'll replace mine!
Guessing they are a main stealer part, OR a lucky breakers find... how many heavy crashes don't ruin them :(
EDIT:: Called the dealer... £239.47 +VAT each side. I can deal with cleaning the guides this weekend :laugh:
Are the belts a sealed loop, meaning you can't just replace the guides? Its obviously not a 'loop' but the sewn ends are way to thick to shove through new guide.
Last edit: 07 Dec 2011 12:16 by adamatdraycott.
  • zaine
08 Dec 2011 10:22 #27535 by zaine
Halford wrote: :woohoo: hope there's been some fix, with better 2010 ones
dont know sorry, just the car i got them front had done about 2k miles so i presumed the belts would have had much less use
looked identical from the outside, were just a different colour belt
bolted in fine
worked a treat, much nicer than my older ones that didnt return very well
  • adamatdraycott
19 Jan 2012 11:52 #31323 by adamatdraycott
Cleaned my guides up a week or so ago and the belts now return fine!
Just used a window wipe and a screwdriver to clean the black crud off :)
Time to create page: 0.148 seconds
