Heater does not warm up ! HELP !
02 Dec 2011 19:14 #27078
Re: Heater does not warm up ! HELP ! was created by mlines
Usually the "quick fix" is to reach below the dash and re-connect the actuator that has been kicked off the heater unit by you or your passenger.
Other than that its then looking for an air lock, thermostat etc (and checking that there is water in there in the first place)
- myers647
02 Dec 2011 22:47 #27100
by myers647
Replied by myers647 on topic Re: Heater does not warm up ! HELP !
Hi mate i had the same problem last year and it was as martin says, i had kicked the heater arm off. If you have a look near the clutch pedal there is two white/cream arms. Put the heater on and move the front arm down with your hand this should turn the warm air on.
it worked on mine .
Thanks
James
it worked on mine .
Thanks
James
03 Dec 2011 00:19 #27103
by facade
At the front, by the radiator there is a white tank with a tube going to the top of the radiator. This should contain coolant to the line marked on the tank.
The thermostat is buried with the engine under the manifold. If the temperature gauge comes up to near the middle fairly quickly it is likely ok.
You won't get a haynes manual, Haynes has never bothered to "photograph a car a little bit like yours , but left hand drive and tell you that fixing anything is too difficult"
You can download a manual, google "jimny manual download"
(Haynes haven't done decent manuals since 1981, and those were reprints of the manufacturer ones)
Replied by facade on topic Re: Heater does not warm up ! HELP !
dj.brian wrote: but where should there be water ? And where should the thermostat be ?
Is it a case of popping down Halfords and buying a haynes manual ?
- ZookFastback
03 Dec 2011 03:59 #27105
by ZookFastback
Replied by ZookFastback on topic Re: Heater does not warm up ! HELP !
Is the Jimny new to you? Has the heater worked previously? I ask because one of my friends bought a Jimny and the heater had been by-passed because the heater core had died. I had to replace a heater core in my own Jimny recently and all up it cost nearly $1500 which is why, I would say, that my mates' heater was by-passed.
03 Dec 2011 19:13 #27163
by facade
If the temp gauge is in the middle, the heater should be blowing hot.
Taking a long time to warm up is a sign of a faulty thermostat.
On a soft top car the thermostat is easy, it is under the spigot where the top radiator hose joins to the engine, drain the water out of the radiator into a bucket, using the white key like drain plug in the bottom of the radiator, remove the hose at the engine end, undo the bolts, remove housing. Replace thermostat with jiggle pin to the top, replace housing and hose. Put coolant back in through silver cap on top of radiator.
- mcjimny
03 Dec 2011 19:50 #27167
by mcjimny
Replied by mcjimny on topic Re: Heater does not warm up ! HELP !
Thermostat is a very simple diagnosis. Start the car from dead cold, hold the top hose. If it heats up gradually the stat is stuck open, if it stays cold and suddenly goes hot its working fine, if it doesn't warm up at all its stuck shut.
Time to create page: 0.182 seconds
