body lift
  • jason92
18 Nov 2011 19:33 #26044 by jason92
body lift was created by jason92
hi just wondered if i fit a 2"body lift what else do i need to do?? lengthen steering?? prop shafts etc??
  • doncarlyon
18 Nov 2011 19:54 #26047 by doncarlyon
Replied by doncarlyon on topic Re: body lift
Steering
Brake pipes
Transfer box lever needs bending
Bumper wont fit properly...
Cant think of anything else.
  • zuki andy
18 Nov 2011 19:54 #26048 by zuki andy
Replied by zuki andy on topic Re: body lift
when i fitted mine i had to lenghten steering by 10mm and the bolts only just went on the flats on the splines, would have been better at 15mm. prop lenghts dont alter as transfer box is mounted to the chassis. also front bumper will need modifing, and i had to bend transfer box lever a little so it would go into 4low. and also theres a brake pipes union that fastens to the chassis near the engine that needs lifting.
  • r_ogilvy
18 Nov 2011 20:16 #26052 by r_ogilvy
Replied by r_ogilvy on topic Re: body lift
i did a 2" lift, my steering was ok but right on the limit, fuel pipe were ok just moved the ruber pipe a bit.
i had to bend my transfer box lever a bit and add i bit on to make it longer.
make up a small bracket for the brake cylinder, i think it was brakes! when you lift it, it doesnt line up with the holes.
watch the line for the vacum hups i bent mine abit, they are a bit weak
r_ogilvy
18 Nov 2011 20:34 #26056 by mlines
Replied by mlines on topic body lift
How about this,
www.bits4vits.co.uk/store/jimny/steering...jimny-/prod_397.html
-- Sent from my HP TouchPad using Communities
18 Nov 2011 20:57 #26060 by maverick
Replied by maverick on topic Re: body lift
which is why a 3inch spring lift is so much, errrr, less hassle, just extended brake hoses!
Jalapeño, IISY?
Time to create page: 0.104 seconds
