body lift
- bigoffroader
19 Nov 2011 18:19 - 19 Nov 2011 18:20 #26113
by bigoffroader
new springs
longer brake lines
longer shock or shock extenders
caster correction arms or bushes otherwise the car will wander about and the steering wont self centre
could also do with adjustable panard rods to align the wheels
and you may also need a prop spacer
to do it correctly
thats what i needed anyway when i started altering mine
out of the two the body lift is easier and cheeper to do, imo
Replied by bigoffroader on topic Re: body lift
If you do a spring lift you may need some or all of the following:maverick wrote: which is why a 3inch spring lift is so much, errrr, less hassle, just extended brake hoses!
new springs
longer brake lines
to do it correctly
Last edit: 19 Nov 2011 18:20 by bigoffroader.
- jason92
21 Nov 2011 20:21 #26256
by jason92
Replied by jason92 on topic Re: body lift
am doing 3" suspension and maybe a 1" body lift off ebay £25ish
- supergaz
21 Nov 2011 20:47 #26258
by supergaz
Replied by supergaz on topic Re: body lift
I wouldn't go near the cheapo bodylifts on ebay!
I highly recommend the Jimnybits kit
www.jimnybits.co.uk/shop/jimny/jimny-2-/...ift-kit/prod_45.html
The cheapo kits dont come with sleeve bolts and require the originals to be cut out.
- r_ogilvy
21 Nov 2011 21:04 #26260
by r_ogilvy
Replied by r_ogilvy on topic Re: body lift
i agree with supergaz, i think some of the cheaper kits are just plastic spacers and doesn't come with anything.
i think i ruins the drive, mines not as nice to drive since iv had the bodylift, seems to have a little more roll on the corners.
remember the pipe for the valcum hubs i forgot them and pulled them off when jacking it up!
