Gear Box Converting
- mostafa
17 Nov 2011 19:13 #25974
by mostafa
Gear Box Converting was created by mostafa
hi all
i have my 1999 jimny with SOHC and Automatic Transmession........
now i got a problem with the clutchs, and the control unit of the gearbox......acording to the mechanical, as the problem is:
-when i put on "D" it takes time to shift to the first gear
-sometimes it goes as it is on "N" whil driving
-only first gear comes, not 2,3 or 4
the history of auto transmession tells "THE GEARBOX WILL NEVER BE TOTALL AS IT IS AFTER FIXING" and problem will exist.
now what im thing is one of bellow and i need your support:
-try to fix and current gearbox
-change the whole gearbox
-CONVERT TO MANEUAL GEARBOX
and if im converting to maneual i have some Qs:
-does the vitara 1.6 gearbox fit with my jimny?
-does the suzuki carry gearbox fits with my himny?
suzuki carry:
www.google.com.eg/imgres?q=suzuki+carry+...s:0&biw=1280&bih=784
thanks all
suzuki carry:
thanks all
- mostafa
19 Nov 2011 11:50 #26103
by mostafa
Replied by mostafa on topic Re: Gear Box Converting
heeeeeeeelllllllllpppppppp
19 Nov 2011 14:21 #26106
by facade
Replied by facade on topic Re: Gear Box Converting
Your gearbox needs a rebuild by a transmission specialist.
A vitara gearbox will not fit.
Converting to a manual gearbox needs a lot of extra parts.
You could try cleaning the transmission filter in the transmission oil pan and fresh fluid, then add some magic fluid like Lucas Transmission Fix to get a few more miles out of it if you are lucky.
- jo king
19 Nov 2011 19:56 #26128
by jo king
Replied by jo king on topic Re: Gear Box Converting
To convert to a manual will give you a mental meltdown. :sick:
I have a gearbox sat under my stairs as I was going to convert my jimny to a manual then I looked into it and spoke to rhino Ray and he said I would encounter all sorts of problems.
Get another box might be the best option if cleaning it does not work.
You could get a cd manual work shop and see how to strip it.
But I wonder how much the clutchs are going to cost as I bet you cant get copys. :pinch:
If you do a convert you will have to get a manual wire loom, computer and locks and ignition all form one jimny at a breakers plus dash with dials behind. Then a gearbox and a clutch kit, pedals box , flywheel plus bolts. I have a gearbox and a pedal box cheapish.
I sold my auto and got a manual I will never have an auto jimny unless for spares.
- Jimny
21 Nov 2011 01:59 #26224
by Jimny
Replied by Jimny on topic Re: Gear Box Converting
Hi, I just bought and this is 2nd Jimny I owned, The tranny is auto and I would like to convert it to manual tranny. Any tips i should looking into especially the wiring harness modification and if i convert to manual do i use the TCM module anymore?
- mostafa
12 Aug 2012 00:35 #45954
by mostafa
can anyone provide with needed steps with details?
Time to create page: 0.149 seconds
