Vacuum hubs
  • rjd1
14 Nov 2011 20:51 #25792 by rjd1
Replied by rjd1 on topic Re: Vacuum hubs
again there is a quick fix that works well and never had any probs with it
remove hub`s and activte centre you will feel it slot in
remove vac pipe in engine bay tie a knot in it job done
a lot of sj`s used to have active hub`s with no real prob`s
never really noticed a difference in fuel consumption once method used
light will flash on dash when 4wd selected but at least you no they are working
quick cheap efective fix
cheer`s
  • stevengonzalez
15 Nov 2011 05:33 #25797 by stevengonzalez
Replied by stevengonzalez on topic Re: Vacuum hubs
Though Suzuki pipes are expensive the are of best quality and will give be able to serve you for long.I think you should opt for those
  • Hunter K
15 Nov 2011 20:32 #25846 by Hunter K
Replied by Hunter K on topic Re: Vacuum hubs
Crawled under the Jimny tonight. All the vacuum pipes look rotten so gone and bought some AVM manual hubs.
Thanks for the advice. Hopefully they'll be easy enough to fit.
Cheers guys.
