Vacuum hubs
- Hunter K
14 Nov 2011 19:23 #25777
by Hunter K
Vacuum hubs was created by Hunter K
Hi,
Just bought a Jimny (today!!)- happy days.
The 4WD light flashes and, having read your blogs, have found out the metal vacuum pipes fixed to the chasis below the drivers door have corroded with one end broken off where it joins the rubber pipe.. I'm hoping this is the cause of the problem (although the 4WD light flashes, 4WD still seems to engage!).
I'm hoping replacing the metal pipes will cure the flashing light problem. Do you know where I can order replacement pipes?
Many thanks,
Hunter
Many thanks,
Hunter
- Gromit
14 Nov 2011 19:36 #25779
by Gromit
Replied by Gromit on topic Re: Vacuum hubs
Don't bother mate, bin the auto hubs and put some manual ones on, the auto vacuum hubs are shite !!!
- teafortwo0789
14 Nov 2011 20:02 #25784
by teafortwo0789
Replied by teafortwo0789 on topic Re: Vacuum hubs
The OEM Suzuki pipes are very expensive. You could do as Gromit suggests and go to manual hubs, which are less convenient but more reliable.
However it is possible to buy copper fuel line or central heating microbore pipe and and make some up, much cheaper. There are many cures and suggestions to be found on this site. Good luck!
- Hunter K
14 Nov 2011 20:05 #25785
by Hunter K
Replied by Hunter K on topic Re: Vacuum hubs
Thanks. I'll look into the manual hubs.
- Hunter K
14 Nov 2011 20:06 #25786
by Hunter K
Cheers mate. I'll try and cobble something up. If it doesn't work, I'll go to manual hubs.
- Licksan
14 Nov 2011 20:46 - 14 Nov 2011 20:47 #25790
by Licksan
Replied by Licksan on topic Re: Vacuum hubs
As others have said go with manual hubs! Auto hubs are a nice idea but very poorly implemented IMO.
I spent the best part of two days feckin about cleaning every part of the system and re piping it all with silicone vac hose and the damn things still wouldn't work properly!!
Connected individually directly to the vac solenoids they worked but when T'd together they would intermittently activate! As if the vac was not always strong enough even though the hubs were lightly lubed with oil not grease. Far too unreliable and unpredictable and a lot of messing about for nothing!
AVM Manual hubs fitted in 30 mins and peace of mind
that they are there when you really need them!
Got all the old pipe work some of which is usable which you are welcome to have if you are nearby?
Last edit: 14 Nov 2011 20:47 by Licksan.
