crank shaft nut
- grumpy22
11 Nov 2011 20:12 #25574
by grumpy22
crank shaft nut was created by grumpy22
started doing the cambelt tonight. everything going OK but I can't shift the crankshaft nut. Tried my usual tricks but still wont budge. (in gear hand brake on, in low handbrake and chocked wheel, finally breaker bar between chassis and anti roll bar and turning over engine on key)
nothing shifts it....
it's a 17mm nut but what sort of torque.
I'm guessing I can't change the belt without remiving the crankshaft pully so the nut has to come off
suggestions please (Oh the rad is stll in place access is fine)
thanks
thanks
- grumpy22
11 Nov 2011 20:27 #25576
by grumpy22
Replied by grumpy22 on topic Re: crank shaft nut
just had another look with a mirror, can I just remove the smaller nuts to remove just the pulley???
- grumpy22
12 Nov 2011 10:34 #25587
by grumpy22
yes!
job done
job done
- dirtydogz
12 Nov 2011 11:23 #25593
by dirtydogz
Replied by dirtydogz on topic Re: crank shaft nut
well done:woohoo:
12 Nov 2011 19:18 #25615
by facade
Replied by facade on topic Re: crank shaft nut
I'm amazed that a breaker bar under the chassis rail wouldn't fetch it off with the starter. :ohmy:
- grumpy22
12 Nov 2011 19:56 #25618
by grumpy22
Nope, that one worked even on landies. Removing the small bolts means the crank nut can stay in place though.
More problems and solutions and further problems in another post though
G
G
Time to create page: 0.192 seconds
