Rear Diff bearings
- supergaz
10 Nov 2011 18:44 #25513
by supergaz
Rear Diff bearings was created by supergaz
Hi
I've a knocking noise and excessive play from my rear axle flange, it is also leaking oil.
So the bearing has gone.
Is this an easy fix, and where can I get this part from?
I am not shy with the spanners as I am an engineer, but I have not yet played around with diffs yet.
I was planning on removing the diff as I will be fitting a lockrite, so was hoping to kill 2 birds with 1 stone.
Thanks.
Thanks.
10 Nov 2011 19:48 #25516
by facade
Replied by facade on topic Re: Rear Diff bearings
You will need a pair of unbelievably expensive bearings, a new oil seal and a crush spacer from between the bearings.
It would probably be better to swap the differential as the crownwheel and pinion will wear excessively with shot bearings and become noisy when you have replaced them back to spe
The following user(s) said Thank You: supergaz
- supergaz
10 Nov 2011 19:57 #25517
by supergaz
Replied by supergaz on topic Re: Rear Diff bearings
Thanks for that, better save up now for a new diff, was hoping to just change the pinion seal and bearing.
10 Nov 2011 22:05 #25525
by kirkynut
Replied by kirkynut on topic Re: Rear Diff bearings
Ask CAM Suzuki for a price on a second hand diff or keep an eye on ebay. I've seen them for about £75.
- darthloachie
11 Nov 2011 07:41 - 11 Nov 2011 07:43 #25531
by darthloachie
Replied by darthloachie on topic Re: Rear Diff bearings
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
Last edit: 11 Nov 2011 07:43 by darthloachie.
- supergaz
11 Nov 2011 14:48 #25561
by supergaz
Thanks Guys. Going to have to wait a while before I can buy a diff. I got a great price from KAP as I was passing today, so will be popping in once I get some cash together as I have spent up on another big toy this month.
She wont be happy if I go spending more! and I cant hide it as she works at the bank.
