most common tyre size?
  • r_ogilvy
30 Oct 2011 17:05 #24807 by r_ogilvy
most common tyre size? was created by r_ogilvy
im just about to buy some off road tyres, more than likely insa turbos.
i wanted to go for 31 inch tyres, but thought i would check the most common used tyre size used on jimnys?
then i would no if to go smaller or not.
i want it mainly for boggy mud, to keep up with everybody
i was thinking of these tyres (if the pic shows) or are they to much for the jimny, dont want be breaking things
any help would be great, thanks richard
30 Oct 2011 18:59 #24823 by kirkynut
Replied by kirkynut on topic Re: most common tyre size?
Quite a few of the Winch Challenge boys run that tread pattern, however, some I have spoken to have stated that they have little sideways grip - important off road, especially on side slopes and to stop you sliding into ditches and holes you don't want to be in!
The Insa Turbo Special Track pattern is good. I have Malatesta Kaimans which are in the same tread pattern.
31" needs a large lift and alot of wheel arch cutting to fit.
I have 215/80/15's and a sagged 3" lift and with a small amount of cutting and taking out the arch liners on the front they only catch a little occasionally.
  • r_ogilvy
30 Oct 2011 19:32 #24835 by r_ogilvy
Replied by r_ogilvy on topic Re: most common tyre size?
i did have 235/75/15 a/t tyres, i think is 28-29 inch, is bigger tyres the better? or will 235/75/15 be ok with insa turbo style tyres on make alot of differance than my old tyres,
i just see people trying to put the biggest they can on, if theres not much difference between a 29 than a 31 i would rather put 29s as there cheaper, i go out with a couple of vitaras and they seem better in deep mud, thats why i was gonna try 31s
  • r_ogilvy
30 Oct 2011 19:36 #24839 by r_ogilvy
i have only got a 2 inch sus lift, 2 inch body lift, i have cut the arches up to the lip about an inch around the arch
will that take 31s without rubbing everywhere?
richard
  • supergaz
30 Oct 2011 20:35 - 30 Oct 2011 20:35 #24859 by supergaz
Replied by supergaz on topic Re: most common tyre size?
My 235/75/15 special tracs were spot on today! :-)
Don't recommend them on the road though.:sick:
Last edit: 30 Oct 2011 20:35 by supergaz.
  • jason92
30 Oct 2011 22:03 #24876 by jason92
Replied by jason92 on topic Re: most common tyre size?
i have 235/75/15 and love them
