More power?
- Sandez
17 Oct 2011 22:44 #23902
by Sandez
Replied by Sandez on topic Re: More power?
It would depend on the cost of a supercharger in the end? Installation, tuning, extra components and even at safer psi will cause a little extra wear on the engine.
Only guessing here but you would probably only get 50% increase, also depending on how many components you replace, injectors, ecu etc.
If an engine swap costs less, whether it is a 1.6 or 1.8, are pretty much a straight swap, will give you 50% extra torque and 25%-50% increased power respectively, are unmodified so should last longer with the potential to increase power further, I cant see supercharging making any sense
- nads1978
18 Oct 2011 04:46 #23904
by nads1978
Thanks for the info, which model of car has these engines? Thanks.
Replied by nads1978 on topic Re: More power?
Sandez wrote: Iwhether it is a 1.6 or 1.8, are pretty much a straight swap
- Sandez
18 Oct 2011 05:08 #23905
by Sandez
The 1.6 is out of the some Grand Vitara and Swift models.
The 1.8 is from the Liana here in Aus. Not sure if its available anywhere else.
There should be a thread on here somewhere on the 1.6 conversion. There might be a member or 2 that has done it as well, so I would suggest you speak to them and find out exactly what would be needed.
- doncarlyon
18 Oct 2011 06:18 #23907
by doncarlyon
Replied by doncarlyon on topic Re: More power?
Mine could do with a bit more power, going up hills flat out at 40mph isnt much fun ha ha!
- Mud_Muppet
18 Oct 2011 06:54 #23910
by Mud_Muppet
Great minds think alike, ive also got a Evo as my other car, Evo 6 gsr but mines on running 370bhp, you on the MLR by any chance aswell ????
Replied by Mud_Muppet on topic Re: More power?
nads1978 wrote: That's certainly interesting! However, not sure the missus would be too impressed. I get enough grief over my Mitsubishi.
- nads1978
18 Oct 2011 07:01 #23911
by nads1978
Hi, yep.... same user name on MLR!
The Jimny is the best car we ever bought, I've had ~30 cars in 15 years. It just needs a bit more grunt. I'm surprised no one has developed software to tweak the OEM ECU. I wonder if it's the same ECU as others in the range.
Time to create page: 0.166 seconds
