More power?
- nads1978
17 Oct 2011 05:41 #23811
by nads1978
More power? was created by nads1978
Can I squeeze a little more power from my 1.3 Auto 2007 Jimny?
It's a great car, but struggles a bit too much when on slow or fast hills (country side/motorways)
Is there a straight swap 1.6 in the range? If so what are the differences, bottom end, head, etc?
- TomDK
17 Oct 2011 06:37 - 17 Oct 2011 06:40 #23816
by TomDK
I'm planning on putting an engine like this one into a Jimny next year
Seen it fitted in a SJ, so it should also be possible in a Jimny
And yes I know. Lots of work
Replied by TomDK on topic Re: More power?
Last edit: 17 Oct 2011 06:40 by TomDK.
- nads1978
17 Oct 2011 07:05 #23818
by nads1978
Replied by nads1978 on topic Re: More power?
That's certainly interesting! However, not sure the missus would be too impressed. I get enough grief over my Mitsubishi.
- TomDK
17 Oct 2011 07:11 - 17 Oct 2011 07:13 #23820
by TomDK
Yeah - Noticed you have an Evo 7, awesome
check out youtube and some of the supercharged 2.9 Cosworth engines, 500-750 bhp
But then again, with this much power in a Jimny, you will need stronger Transfer box, stronger axles and probably lots of other things changed
Last edit: 17 Oct 2011 07:13 by TomDK.
- X-Eng Simon
17 Oct 2011 07:16 #23821
by X-Eng Simon
Replied by X-Eng Simon on topic Re: More power?
Almost certainly!
If you convert to a programmable ECU like Megasquirt or Omex and play around with the fueling / ignition timing you can normally get a fair bit extra without significantly altering the engines mechanics.
Si
Si
- TomDK
17 Oct 2011 07:19 - 17 Oct 2011 11:43 #23822
by TomDK
What about fitting a small supercharger or turbo to the stock engine. I read somewhere that if you don't go above 5-6 psi, it's possible with standard engine. But bigger injectors would be needed I guess. And/or a programmable ECU of some sort?
What do you think?
X-Eng Simon wrote: Almost certainly!
Si
What do you think?
Last edit: 17 Oct 2011 11:43 by TomDK.
