Sticky 1st gear
- Chilgrove
14 Oct 2011 15:04 #23668
by Chilgrove
Sticky 1st gear was created by Chilgrove
I often find engaging 1st gear after being stopped is a bit "sticky" and sometimes it does not properly engage so gearbox gives the 'orrible noise we all know and love. Is there any lubrication I can apply to the gear stick or is this just worn synchromesh? All ideas and suggestions gratefully received. By the way I am careful to press down the clutch fully. Mileage showing 19000 only. Year 2006.
- v8dougie
14 Oct 2011 17:38 #23675
by v8dougie
Replied by v8dougie on topic Re: Sticky 1st gear
Have you checked the manual gearbox fluid level? Top up with 75w90 if it does not trickle out when you remove the filler plug.
Mine can be difficult to engage when slowing down unless the speed is low enough, and 2nd is difficult for the first 5mins when cold, but my car has done 96k!
HTH
HTH
14 Oct 2011 19:24 #23679
by facade
Replied by facade on topic Re: Sticky 1st gear
Mine won't go in 1st when cold.
I use sx75w90 gear oil and it is a little better than when I had it.
If it is moving I just slip the clutch gently in 2nd. When stationary it is a case of dabbing the clutch up and down until it feels like going in.
Mine has done 110,000 miles.
fill this in
motinfo.direct.gov.uk/internet/jsp/ECHID...-History-Request.jsp
you may get a surprise like I did....
Chilgrove wrote: Mileage showing 19000 only. Year 2006.
fill this in
- Chilgrove
15 Oct 2011 09:09 #23685
by Chilgrove
Replied by Chilgrove on topic Re: Sticky 1st gear
Thanks for the advice. I do find going into 1st easier if moving forward slowly. Worse usually if completely stopped. Is it easy to check the gearbox level?
15 Oct 2011 09:53 #23688
by facade
The filler plug is up on the side of the gearbox, right where you can't get at it.
You will need one of those oil filler syringes that machine mart sell to get oil into it.
- v8dougie
15 Oct 2011 09:57 #23689
by v8dougie
Location of filler correct, BUT do what I did and get one of these :
It is by far the best purchase I have ever made, it is so easy to fill these gearboxes, diffs, transfer boxes or anything similar. Well worth the investment
HTH
facade wrote: The filler plug is up on the side of the gearbox, right where you can't get at it.
HTH
Time to create page: 0.103 seconds
