Steering damper
- Thank you received: 706
03 Oct 2018 19:35 #196481
Replied by jackonlyjack on topic Steering damper
In a word yes I fitted 225/75/16's and found it sort of bouncey
I made my own brackets and used a disco one damper really easy to make and fit
03 Oct 2018 20:22 #196483
by sniper
Replied by sniper on topic Steering damper
I'm only on 215's and found the steering damper a great improvement, making the car feel more solid, less prone to wander. I suppose it just slows things a little and lets my dodgy reactions keep up. A must do if you look at cost v benefit.
I bought a JB kit but I've seen what jack fabricated from a little box section, bit of cutting and drill a few holes. Looks like it was engineered and if you can beg a bit of box section, it just needs some time and a few bolts.
sniper
sniper
04 Oct 2018 19:36 #196499
by kirkynut
Replied by kirkynut on topic Steering damper
I have 215.80.15 Malatesta Kaimans and removed mine for the MOT as the bushes were shot and it didn't have one from the factory.
I can notice a tiny bit more bump steer but it's not enough for me to say I miss it.
I'll get more bushes as and when but I'm in no rush. It just depends on when I next make an order from the Big Jimny shop!
- Kabani
07 Oct 2018 01:07 #196542
by Kabani
Replied by Kabani on topic Steering damper
Hello. At the end, yes. It feels way more solid with the damper.
I installed it because I had a death wobble experience. I thought it was the solution but it was more than that. old Rod ends, Wide tyres, loose bolts etc... I fix all those and then I was able to accelarate to 120 km/h with no wobble.
I still want to fix something to my current damper installation.. I hope you dont make the same mistake.
The weight of bracket near the steering arm does some torsion downwards and I feel that is gonna wear the rod end prematurely.
If anyone has had the same issue and came with a solution please share it....
12 Oct 2018 20:21 #196717
by kirkynut
A steering damper is never the answer to Death Wobble. It might help mask the symptoms but cannot solve the cause.
There are a lot of components on the front axle that can cause it and each of them have to be sorted out to solve Death Wobble properly.
- Kabani
14 Oct 2018 08:25 #196754
by Kabani
Indeed, I found oiut the hard way.. I could have fix the wobble attenting more relevant points.... at least I got to spend some Jimny mod time... I like doing my mods...
Steering damper.... it helps.. I am running with no ARB and with steering damper... I feel the driving experience way better.
